Hello,
Is there a way to insert automatically between each page another page?
Now, I have to do it manually !
example : 1 invoice ; 10 pages long ; between each page, I need to put the sales conditions
and then print the invoice recto/verso.
Thx.
You can do this with a simple JavaScript running in e.g. an Action or a Custom Command. Look at David's solution here: Add a page every other page until the end (JavaScript)
If you want to know how to create a custom command, see here: Create Custom Commands in Adobe Acrobat DC Pro - KHKonsulting LLC
Yes, it can be done using a script, like this one I've developed:
http://try67.blogspot.com/2012/03/acrobat-insert-one-pdf-file-into.html
Hello,
Thank you.
I will try to make a javascript.
Hello,
Thank you again.
It is already done.
Very easy to fix (when receiving big help !)
