Hello everyone , I am new to after effects and I don't know anything about after effects , layers , composition . . . NOTHING ! ! ! So I'll be asking you some ' very stupid questions ' along the way so please pardon my ignorance.
Question No.1 : I've started my first lesson by composition > new composition etc. but when I click and select a background color , etc the color does not show up in the composition panel . . . . what am I doing wrong ?
Thanks.
If you get a tranpsarent background like a grid ( checkerboard ) there is a button called Toggle transparency grid ( it looks like a grid )
let us know if that helps.
wow, that's it. Accidentally clicked on it. Thank You
Thank You
The background color of a comp WILL NOT RENDER. The only use for adding a background color is to provide edge color adjustments to alpha channels when they are rendered pre-multiplied with color. There is no other practical use for a composition background color.
If you want a colored background add a colored solid to the composition and put it on the bottom layer.
I have never met anybody that has successfully just opened up After Effects and started working with any kind of success. If you are new please start here: Basic AE
You also need to study up on video standards and video compression. When you first start out none of you compositions should say Custom in the Composition settings and you should not modify any of the output module or Adobe Media Encoder rendering presets.
I started using AE last week and now I'm a pro making $900/day at a high end mograph agency, sry dude, some of us are naturals!
