[Acrobat] cannot rotate stamp
Feb 18, 2017 Feb 18, 2017
I am using Adobe Acrobat Pro DC version 2015.
After stamping a document, I cannot rotate the stamp.
I am familiar with the process, but the handle does not turn into the rotate symbol.
How can this problem be fixed?
Edit and convert PDFs
6.3K
Community Expert , Nov 09, 2017 Nov 09, 2017
An oval annotation can't be rotated. Only a Stamp annotation can be, or a free text annotation (and only by 90 degree intervals).
Are you able to move it around on the page?
Yes, I can move it without any problem.
The mouse pointer (hand or arrow) does change into the double arrow that allows to move the stamp. But never changes into the rotate symbol when getting close to the rotating anchor above the stamp.
What's the exact version number of your Acrobat? Also, what's your OS?
It says Version 2015 (Classic), Version 2015.006.30244
And my OS is Windows 10 Pro 64-bit
Mar 18, 2017 Mar 18, 2017
I have the exact same issue. It began in February, likely after a data patch.
Version 2015 Release (Classic) | Version 2015.006.30280
The grip handle above the stamp will not select. I can move and resize, just not rotate. This is a function I use on a daily basis.
Guest
Nov 08, 2017 Nov 08, 2017
I have a similar issue.  After drawing an oval, the handle doesn't even appear, therefore, so rotating option!
Nov 12, 2018 Nov 12, 2018
I don't think these are "oval" annotations, they are simple stamps.  Still not working??
If it's a stamp then it should be possible. Click on it and look for the tiny white circle about it (marked in red below):
When you hover with the mouse above it the cursor should change to this icon:
Click the left mouse button, hold it down and then move the mouse. It should look like this:
When you let go, the stamp will be rotated:
May 15, 2017 May 15, 2017
This problem remains unsolved. Can anybody kindly assist?
Feb 11, 2022 Feb 11, 2022
Today, I mistakenly created a new posting in which I posted a Potential solution to the "Cannot rotate the stamp" problem (?)  to this problem.
I apologize for not realizing that I should have posted it here instead.
                    Marc B. Hankin
Jul 20, 2017 Jul 20, 2017
I have a problem where I can rotate my custom stamp but it rotates all iterations of the stamp in the file.
Aug 28, 2021 Aug 28, 2021
Hey i know this is a old question but I had the same issue and was using a round stamp I found that when trying to rotate you need to look for the rotate simble at the top middle of the blue retangle box that appears around the stamp when you click on it. hope anyone that googles this question can find my comment and it helps.
