Hello guys, does anyone know if muse will release AMP in their new updates?
[Moderator's note: Moved from non-technical Lounge to Muse forum]
I checked with the team and AMP is not on the current roadmap, but they are exploring the possibility of adding it at a later date.
Like it was correctly mentioned, there are challenges with integrating AMP in Muse.
Preran
Muse uses a lot of scripts...the AMP protocol would prefer not to. Much more to it than just this but...
Word Press had to come up with an AMP plugin to address the many requests for implementing AMP.
it works okay but it ain't pretty if you have a lot going on ...it strips out a lot in order to load the page fast.
I can see the challenge Muse has... but i think after seeing how some AMP plugins function on other platforms it's doable....someday.
Preran
Thank you Preran...it's been a question coming up more and more when bidding or recommending Muse for intrasites and testing sites. especially sense again Google and other majors use AMP as a ranking signal.
maybe a duplicating module similar to what Word Press has as a plugin...for AMP...although like I said ...it's not very pretty...
appreciate the kind response
No worries. I also suggest using this link Adobe Muse CC: Feature Ideas to register your feature request with the team.
Preran
Slightly dated posted, and I will check with the team if they have any latest update.
Adobe Muse page export as AMP HTML
Preran
That would be great...seems like a quite a challenge ...App development is always a fast moving target
Gracias por resolver mis dudas , Ojala salga lo más pronto posible ya que AMP es la nueva tendencia en SEO
