When I go to Modify > Transform > Scale & Rotate I get this very small cut-off window that barely shows the scale text field. It is not resisable.
Has anyone else experienced this issue? Any known fix?
Info:
Windows 10 Pro
Adobe Animate CC Version: 16.1.0.86
[Moved from non-technical Forum Lounge to specific Program forum... Mod]
[Here is the list of all Adobe forums... https://forums.adobe.com/welcome]
mine looks ok:
but then i have my display at 100% and you probably do not:
you could try the window>transform panel. i find that easier to use and more flexible, anyway.
mine looks ok:
That's exactly what it was. I'm working on a 4k monitor so I have to have it at at least 200% or else things are way too tiny to see.
The whole High DPI problems were fixed recently, but I think there are lingering cases where problems still occur. I know of another panel that has only just been fixed, and I've asked whether the fix for that panel will help the scale & rotate.
Either someone from the Animate team will drop by, or I'll post what they tell me.
As Colin pointed out we have fixed a cropping issue on high resolution HiDPI displays for the upcoming release. Please PM me if you would like to validate this issue on a PR build with this fix.
Mohan
The March update of Animate CC 2017 is now live and contains a fix for this issue. This update also comes with an improved Brush sketching experience and important bug fixes.
Please update your copy of Animate CC 2017 to the latest (16.2.0.24) using Adobe Creative Cloud desktop application. If you do not see the update for Animate under Apps panel then please click on the gear icon and choose Check for App Updates menu.
Mohan
