The "Drag and drop photos" in Lightroom 6 is NOT Working !!!
I wish someone can make this bug or illuminate us! Thanks
P.s. In Lightroom 4.4 this actions was working!
What operating system? What are you trying to drag, and where are you dropping them?
Hi John,
- Windows 8.1 (and is not about the operating system for sure)
- Drag a folder/CR2 files on the Library, like it was working on some older versions!
- Is only working from FILE/IMPORT PHOTOS AND VIDEO!
So you are dragging a folder from Explorer and dropping it into the Library? Where are you dropping it? The grid? It seems to work fine in Windows 10.
- I'm dragging files and folders from : explorer, total commander and acdsee and is not working.
I sad before, this actions ware available on lightroom 4.4 and it was working from explorer, total commander and also acdsee!
Dragging from where to where? Lots of details needed.
If you are dragging from the grid view in the Library module, you need to drag the thumbnail not the gray frame.
I sad before and also to John up in a comment, this actions ware available on Lightroom 4.4 and it was working from explorer, total commander and also Acdsee!
I'm Dragging in the Library, not Develop mode! I also try to drop them in the grid view and the same problem, is not working. After I try in the Shift+Ctrl+I and even in the import window is not working!
Only manual, by searching partition, and director after director! It's annoying!
I'm using Lightroom since 2009, and in some versions is working and in some newer version/updates is not working!
Thanks for the help.
