How would you separate a line of dots into individual items for coloring? Can you turn the dots into objects? I need to recolor some of the dots from black to white to allow type to be placed.
Hello,
Simply select your dotted line and use the menu Object/Path/Outline Stroke.
At this moment, you have a compound path.
Select all your dots and apply Object/Compound Path/Release.
Now, you can select each dot and recolor it.
Hello,
Thank you this worked perfectly.
Pam Swanson
