I have a bunch of ~200k tiff files. I open them in Photoshop, crop them so they are about 20% of the original size, do a save, and the resulting file is about 2Mb - nothing done to the file except cropping. How can they grow so much?
When you save a Tiff you have a choices of using data compression or not and if you want the file compressed which compression method should be used. What options did you use?
None - I just did file>save. No options came up.
So I just opened a file and did save as tiff. With either compression it still comes out to be twice as big doing nothing to the file except saving it in the exact same format.
When I cropped the pic so that it is about 20% of the original and save using compression, it is about the same size as the original.
Personally I'd always work and save as native PSD files and save copies as JPGs for getting them printed, distributing to others and supplying for web use.
True, but all I needed to do was crop and save. I didn't need to do anything else. 3 steps (delineate the area, pick fence, pick save). A lot of files, so the simpler the better.
Then what happened is you open a compressed Tif files cropped the image ans then saved an uncompressed tif file.
Hi
May be your problem in cropping.
If you put only number it will be crop in cm. So, you have to put number with px. Example 1169px
You can try this.
Please also follow the instruction.
To save
As I said previously, if I just open the file and do a "save as" (no cropping) and save compressed (exactly like you show) it still DOUBLES the size and takes way, way longer to do each file then just going to file>save
If the previous file was saved with high compression then opened and resaved without compression then there will be a large increase in the resaved file size.
For an extreme example :
I just saved a TIFF using jpeg compression minimum quality (yes you can use jpeg lossy compression inside an 8 bit TIFF). The file was a TIFF file - sized 311kB.
I opened the file then immediately used "Save As" - this time with no compression. The file size was 30MB - an increase of 96 times.
Dave
I should have added to the above - I am not recommending compression of TIFFs or PSDs. They may take up less space but the longer opening times negate that in these days of large disk drives.
Dave
