Dear Sirs,
I am unable to open LR6. It says "the entry point_crtCreateSymbolicLinkW could not be located in the dynamic link library"
Kindly help me in retrieving the same.
Thanks & Br,
Mohan Bheema
Try to reinstall MS VC re-distributable: Download Visual C++ Redistributable for Visual Studio 2012 Update 4 from Official Microsoft Download Center
Remove Lightroom, reboot and reinstall. Post back if it does not fix the issue.
If you want to download again: Install Photoshop Lightroom
I tried to uninstall LR6 and reinstall with my Legal Serial Number, but still no luck.
Pls advice me on what I could do????
If I install Photoshop LR, do I need to pay something additional or will the same Serial Number work????
Await your suggestions and advice.
Thanks & Br,
Mohan.
After you did the install a second time, are you now saying that the DLL problem is gone and are now having a serial number problem?
No it's the same problem with the DLL:-)))
Br,
Mohan.
When you reinstall, make sure you have administrative privileges.
Also, make sure to reboot after removing LR and before re-installing.
What is your OS?
When exactly does this error appear?
After installing and putting in the Serial Numbers, the LR icon shows up on the desktop. When I double click the icon to start, it shows ( the procedure point _crt Create symbol LinkW could not be located in the dynamic link library)
This is it :-)))
Try to reinstall MS VC re-distributable: Download Visual C++ Redistributable for Visual Studio 2012 Update 4 from Official Microsoft Download...
