Hi
Go to the Windows reliability monitor (type reliability into the windows search box)
Click on the Red circle with white cross at the time of the issue.
In the list of critical events look for Photoshop.
Double click on Photoshop, in the list, and you will get a report about the crash
Paste it here so we can take a look and try and advise you.
Note : If the report mentions Lavasoft - uninstall Web-Companion / Adaware and you should be OK.
Dave
atio6axx.dll is part of the AMD graphics driver package. Have you tried updating your graphics driver from the AMD website.
Dave
Which graphics driver would I need ? AMD A8 RADEON Graphics R5 M320 is what it says on my computer thanks
It sounds like a notebook. If so, on the link I gave you fill in the boxes as below
Then click Display results:
Dave
wheres the link ? thanks mate you have been very helpful
The top one (17.2.1) is the latest, and the version I have here.
Dave
ok ive downloaded the application , so just run the download ?
Yes - just run it and accept the defaults if it gives you any options.
Dave
ok its installing .. so what does this application do ?
It will update the video drivers on your PC to the latest versions. The crash report you shared earlier was related to a video driver problem. By installing the latest version you can ensure that any bugs that have been discovered and addressed by AMD are eliminated.
It is always the first step in eliminating an issue.
Once installed - restart your computer , then try Photoshop again. There is a good chance that updating the driver will correct the problem.
If you do get another crash make a note of exactly what you were doing at the time of the crash and get the latest reliability report relating to that crash.Also check what version of Photoshop you are using. The current version is CC2017.0.1.
Dave
ok no worries yes I am using the latest version of Photoshop its also a subscription service , that's why it made it more frustrating as I am paying for it
Hey mate photoshop was working fine for like 4 hrs and this message come up again
Is the reliability report showing the same message on the latest crashes or has it changed?
Dave
just received this one now
Hi
That is still showing an issue with your graphics.
Given that you have already updated the driver, can you go to Photoshop Preferences - Performance and under graphics processor settings - click on Advanced settings. Change it to the next setting down i.e. if it is set to Advanced - change it to Normal; if it is set to Normal change it to Basic.
Then click OK and restart Photoshop
Dave
HI again, mate made no difference unfortunately im going to have to unsubscribe from this product its doing my head in and another artist I work with is experiencing the same error code so its not just me now ..
Aaron
Hi
Before doing that I would contact Adobe and see if they can look at your system directly and help you.
Follow the links and you can chat or phone
Dave
I Have tried that several times and got nowhere , this product is faulty and wasting my money and time
No your computer, IE your notebook, is faulty. More than likely the GPU is overheating. Clean out the dust in the air vents. Don't use the notebook on a soft surface, that builds heat and stops proper airflow. Try turning the GPU option off completely in PS and test.
