I am working on a project in Captivate that uses a good many pre-created .swf files. I don't know what program was initially used to create them, but some need updated. Here is one of them:
I am able to change the text, and move / edit other items. However, the two valves that are circled need to blink red. They blink in the originally published .swf file, but I can't figure out how to get them to blink after I edit other information.
you need the fla to edit that in flash/animate.
you can try decompiling to recreate the fla if you don't have access to it. sothink makes the best decompiler, imo.
ok, thank you.
you're welcome.
I have the .fla file now in Animate, but unsure as how to proceed. I just need to get two valve symbols to blink, glow, or flash...whatever the correct term is in Animate.
you need to find that instance on the main timeline or nested inside some other object that's on the main timeline.
you can determine the approximate frame where you'll find that instance by checking the frame rate and the duration the swf plays when that instance appears on stage.
