Hi
We've been using Adobe Reader to allow our users to fill electronic PDF forms from our app by launching an VIEW Intent with a File URI. This has been working fine until Android Nougat/7. Strangely enough Adobe Reader doesn't seems to support EDIT intents, but still allows us to use a VIEW intent for form filling. With Android 7/Nougat you are now required to use a Content Uri and a FileProvider to grant external apps access to your files in your app security sandbox. We've made the changes to our code to use the FileProvider for API 24 and later. Adobe Reader launches successfully and you can do form filling, but it seems to make a copy of the PDF instead of working on the file that directly that we grant Read/Write access to via the Content URI.
What are the supported intent actions for Adobe Reader on Android? Does it only support VIEW intents? What about EDIT intents? How can we get Adobe Reader to use the content URI we provide instead of making a copy of the file? Any code sample of how this can work with Adobe Reader would be great. We have tested our code with other PDF readers like Xodo PDF reader and they all work great. However, we would prefer for our users to stick with Adobe Reader.
Any feedback from Adobe would be appreciated
Hallo cjlotz!
I am facing the exact same problem, but with my implementation it isn't working with xodo either!
Any chance you can share your implementation so that I'm getting at least xodo to work?
Kind regards!
stef
I have the same problem, other applications like Xodo work well just sending the document with ACTION_VIEW, it actually asks what to do when the file is being opened, if it should create a copy or work with the same file.
intent = new Intent();
intent.setAction(Intent.ACTION_VIEW);
intent.addFlags(Intent.FLAG_ACTIVITY_NO_HISTORY);
intent.addFlags(Intent.FLAG_GRANT_READ_URI_PERMISSION);
intent.addFlags(Intent.FLAG_GRANT_WRITE_URI_PERMISSION);
intent.setDataAndType(fileUri,"application/pdf");
as a sidenote for anyone having troubles for this, remember to generate the uri with the right permissions as well, in my case since i picking a file from the system i use
public void scanFile(){
Intent intent = new Intent();
//intent.setAction(Intent.ACTION_GET_CONTENT);
intent.setAction(Intent.ACTION_OPEN_DOCUMENT);
intent.addCategory(Intent.CATEGORY_OPENABLE);
intent.setType("application/pdf");
startActivityForResult(intent, 1212); // 1212 is just a flag for my app
And for the developers i have the same problem on iOS, you really need to implement the URL schemes on iOS and share its format on your page so developers can open a pdf directly with adobe.
We are facing the same issue. Can anyone from Adobe suggest a solution, please?
Hello, I'm also facing the exact same problem.
How can I open my document and force acrobat reader to modify the original file and avoid to create a copy ?
Is this feature going to be fixed soon ?
Best regards,
Did you find a solution? I'm facing the same problem. Thanks
