Hello,
After I opened the Lightroom , add the pics on folder then tried to import the pics but doesn't showed in that Folder.
But showed inside of other Folder with pics I imported before.
thank you for reading,
James
So you are saying that the problem is in the Library module, I thought you were talking about a problem in the Import dialog box.
The first thing I think might have happened is that you (accidentally?) imported the photos into a different folder, that is why they don't appear in this folder. What happens if you click on "All Photographs" on the left hand side of the Library Module (under Catalog) and then search for the photos by scrolling up and down, can you find the photos this way?
Explain this in a lot more detail. I don't understand what you did or what happened.
Sorry,
Let me put it other way,
When I tried to import the pics, Lightroom doesn't show pics .
Why these pics doesn't showed?
James
I'm still looking for a lot more detail. Emphasis on "lot more" detail.
What does Lightroom show when you try to import the photos? Can you describe what you see, or show us a screen capture.
what do you mean by lot more detail,
I did said Lightroom doesn't show pics from the folder where i tried to import
What do you see? Describe what you see, as if you were talking to someone who can't see your computer screen.
I thought it was simple to explain.
When I want to import the pics to work on LIghtroom.
First I have to import the pics.
so I click the Import button to import the pics.
then I look for the Folder whee my pics are.......here Lightroom doesn't showed.
thank you for patient,
James
Show me a screen capture.
I have eight more pics in that Folder , pics for lashow, but it won't showed or can't read(?)
Thank you,
I see those pics in Previous Import Folder.
What did I did wrong here?
thanks for your patient and helping other,
James
You have accidentally imported the photos using COPY and so Lightroom thinks they are in a different folder.
thank you good day
