Random Frame
Feb 23, 2017 Feb 23, 2017
I have identified a button.
This button was going to the next frame.
But I want a random frame.
Would you like to see sample code.
thank you so much
3.0K
Enthusiast , Feb 24, 2017 Feb 24, 2017
Say your button has instance name randomFrameBtn, add this code (adapt the minFrameNb and maxFrameNb to your timeline) :
randomFrameBtn.addEventListener( MouseEvent.CLICK, goToRandomFrame);
function goToRandomFrame( event:MouseEvent): void
    var minFrameNb = 5;
    var maxFrameNb = 20;
    var randomFrameNb = minFrameNb +Math.floor( Math.random() * (maxFrameNb - minFrameNb + 1));
    gotoAndStop( randomFrameNb);
What software are you using?
Animate CC
I have just started and I haven't any information about coding
I'm going to move your post over to the Animate forum. The Coding Corner​ forum is more for general coding stuff whereas the Animate forum folk will be able to offer you more specific help for Animate.
Code to go to the next frame might look like this:
this.gotoAndStop(this.currentFrame+1);
Code to go a frame that is up to 10 frames ahead of where you are now would look like this:
this.gotoAndStop(this.currentFrame+Math.random()*10);
If you wanted to jump to a random frame starting at 15 and ending at 25, it would be like this:
this.gotoAndStop(15+Math.random()*10);
Math.random() gives you a value between 0 and almost 1. Multiplying that by 10 would make the number be from 0 to almost 10.
Enthusiast ,
A downloadable example of playing the different frames/states of a timeline in random order here :
https://forums.adobe.com/message/9309084#9309084
Thank you, AMULI but I am so bad in coding that I do not understand most of the writings.
I will explain my problem;
There were sample codes in Animate CC
Random number generation code;
function fl_GenerateRandomNumber_4(limit:Number):Number
{    var randomNumber:Number = Math.floor(Math.random()*(limit+1));
     return randomNumber;
trace(fl_GenerateRandomNumber_4(100));
AND
Next frame pass code;
newnumber.addEventListener(MouseEvent.CLICK, fl_ClickToGoToNextFrame);
function fl_ClickToGoToNextFrame(event:MouseEvent):void
{  nextFrame();   }
My question is;
How do I add this code any button?
For example, I have a button which name is "newnumber"
and I want, when I click this button, it goes to random frame
Enthusiast ,
I guess, it's not totally random ! Which range of frames ? Said differently, what are the minimum and maximum frame number your random computation should return ?
Enthusiast ,
    var minFrameNb = 5;
Thank you very very very much .
It works like a machine
Enthusiast ,
Feb 25, 2017 Feb 25, 2017
You're welcome, emrek16464832​
Apr 03, 2017 Apr 03, 2017
I'm looking for almost exactly the same technique (just don't want to have to click anything for the function to work — want it to happen on load/refresh). That said, I'm simply trying to get this example to work, but to no avail. When I preview, I see nothing (but I should be seeing my button, at least, or numbers if it's working). Only way I see anything (which consists of the timeline simply looping through) is when I start to modify the code a bit to more closely match other examples I have.  Couple questions:
1. Does this code work for an HTML5 canvas file?
2. Is there a working file I can reference?
3. How would one modify this to randomly select a frame upon load/refresh (no need to click a button)?
Really appreciate any insight/help. I think I'm close, and yet so far away!
What I said in message 4 would work from Canvas, and doesn't need a click:
or:
this.gotoAndPlay(15+Math.random()*10);
if you want it to play from there. In my example it would jump to a random frame in the range of 15 to 24. Change the start frame number and the number of different frames, to match your case.
One thing to be aware of, if you are going to play sound it will fail. In most browsers HTML5 requires a user action before it allows sound to play.
Apr 06, 2017 Apr 06, 2017
So easy … thank you! Works just as expected. My apologies for not inferring the code in message 4 to work for my needs.
May 11, 2020 May 11, 2020
Hello Colin_Holgate
Thank you for your knowledge. I do have a question if you may. I also am working on an HTML5 project.  I would like my project to jump randomly to specific frames for example frame 5, 10 and 15 in a random order onload how do I achieve this?
Kind regards
Something else, if you don't see your button you should look at the developer Console, to see what error message it's giving you.
