Hello
I am working with Photoshop CS6.
Since a few days I have the problem to fill a selected area properly.
For example I have a square on Layer 1.
I then create Layer 2 above Layer 1.
While I am on Layer 2 I select an area which overlaps the square on Layer 1 and I try to fill it.
But it doesn't work properly and only fills the part which doesn't overlap the square on Layer 1.
I am definitely on Layer 2.
Is there something I might have changed in the settings?
Here is screenshot of the problem:
You have used the paint bucket to fill, and you have it set to all layers
Uncheck all layers, or better still use Shift+F5 to fill
Dave
Dave
Thanks a lot! Learned something new and the problem is solved!
You're welcome
Dave
