How many pages can you combine into 1 large PDF? Size of file is not a problem. Have 124 files that need to be combined into 1 PDF with a total of 992 pages. Have run into this problem before but just can't remember or find the simple answer.
There is a big difference between the question of how many pages you can combine into a PDF file versus any limits of how many pages PDF can accommodate in a single PDF file.
In terms of the question of how many pages a single PDF file can contain, there is no set limit. I've personally created files of close to 200,000 pages and half a gigabyte in size without any problem whatsoever. (This was done with InDesign with the XMPie plug-ins, creating PDF/VT files!)
- Dov
Using Acrobat (Pro for sure, Standard maybe) simply combine the PDFs. You may want to do in steps rather than all 124 at one go (a less robust desktop might bog down).
I realize such a large file would probably bog down the system. However, in the past when I was working on parking passes there was a limit on pages. Could this be an InDesign issue or does it even matter now with the newer versions?
- Dov
I did once prove to myself that Distiller could distill, and Acrobat could open, a one million page file. It did work, but the experience had little to recommend it.
Thanks, I don't recommend it either just needed a direct answer.
Hi Dov,
When I try with adobe pro to edit forms in a file with 242 pages, it bogs down (like in other comments) I can only do it in a small number of pages. I am doing that edit to find a faster way to split that file of 242 pages in 126 files, all with different number of pages. Rather than bookmarking each first page of what is going to be each individual file, I would like to be able to do it all by a key field and develop a vba to use on other files. Or IT may hate me by asking to pull me each individual file based on the key field from the database, I have no access whatsoever to the reports I need, or it would be much easier for me. Hope someone can open my eyes on something I may not be seeing. Thank you. Mariana
I'm using Adobe pro and the program won't allow more than 7 pages to scan into a file. scan. Is there a way to set the number of pages higher?
