Hi all,
I bought and download an upgrade licence (not CC) for lightroom6 On Mac. Previously I had Lr5: The Download was right but when I try to install, it stops after having put the serial number and the reason is :"Impossible validation of this serial number for Adobe Lightroom" Contact assistance" (this is a translation). But the serial number is correct, I got it from the email message received from Adobe during the download. I tried several times, but with no results. Please help me.
Thank you in advance
Paolo
Hi all !!
I solved the problem, under guide of assistance, cleaning the file Hosts with an Adobe cleaner tool, and then the installation was completed. Thanks all !!
Bye
Is the computer you are installing on connected to the internet?
If it is are you using any Internet Security software that includes a Firewall?
1 - Yes it is !
2 - Yes the firewall is "ON"
The firewall might be blocking LR from checking to see if that serial number is valid. Once you type in the serial number and click OK the install routine tries to go out to the Adobe r=serial number validation server to check it is a valid serial number. If the firewall is blocking that connection the validation fails. Try turn off the firewall.
Thank you for your help, I tried switching the setting of firewall on "OFF" but the result is the same. I received the same message.
Now it's late here in Italy and I have to wake up early tomorrow morning. But please if you have any suggestions please help me and I will try tomorrow afternoon to solve this problem. Thank you.
First thing to do is Restart your system.
I did it, but with no results.
Take a look here:
https://forums.adobe.com/thread/1079210​
Not validate the serial number during 'installation
Regards
Axel
Hi all !!
Bye
