Locked
1
AIR25 - dx tool failed
Participant ,
Feb 23, 2017 Feb 23, 2017
does anybody else have a problem to package android apk-captive-runtime target with AIR25?
On some Window's machines (both 32 and 64 bit) we have nothing telling dx tool failed error while evaluating building command from command line. On the same machine using older AIR it is working fine.
The command and output looks like:
c:\dev\S3-Build>java -jar ..\AIR-Win-SDK\lib\adt.jar -package -target apk-captive-runtime -storetype pkcs12 -keystore ./cert/S3.p12 Build\S3.apk  android.xml Data/* -extdir ane/
dx tool failed:
Build failed!
Is there some special requirement for AIR25?
David
Air beta
11.9K
Adobe Employee ,
Hello David,
Could you please share the JAVA version (build 1.X.X_XXX-XXX) installed on your machine with OS details.
Adobe AIR Team
Participant ,
Feb 24, 2017 Feb 24, 2017
For example:
java version "1.8.0_121"
Java(TM) SE Runtime Environment (build 1.8.0_121-b13)
Java HotSpot(TM) 64-Bit Server VM (build 25.121-b13, mixed mode)
Computer Information:
    Manufacturer:  LENOVO
    Model:  20C00045MC
    Form Factor: Laptop
    No Touch Input Detected
Processor Information:
    CPU Vendor:  GenuineIntel
    CPU Family:  0x6
    CPU Model:  0x45
    CPU Stepping:  0x1
    CPU Type:  0x0
    Speed:  2694 Mhz
    4 logical processors
    2 physical processors
    HyperThreading:  Supported
    FCMOV:  Supported
    SSE2:  Supported
    SSE3:  Supported
    SSSE3:  Supported
    SSE4a:  Unsupported
    SSE41:  Supported
    SSE42:  Supported
    AES:  Supported
    AVX:  Supported
    CMPXCHG16B:  Supported
    LAHF/SAHF:  Supported
    PrefetchW:  Supported
Network Information:
    Network Speed:
Operating System Version:
    Windows 10 (64 bit)
    NTFS:  Supported
    Crypto Provider Codes:  Supported 311 0x0 0x0 0x0
Video Card:
    Driver:  Intel(R) HD Graphics Family
    DirectX Driver Name:  igdumdim32.dll
    Driver Version:  20.19.15.4444
    DirectX Driver Version:  20.19.15.4444
    Driver Date: 22 Apr 2016
    OpenGL Version: 4.3
    Desktop Color Depth: 32 bits per pixel
    Monitor Refresh Rate: 59 Hz
    DirectX Card: Intel(R) HD Graphics Family
    VendorID:  0x8086
    DeviceID:  0xa16
    Number of Monitors:  1
    Number of Logical Video Cards:  1
    No SLI or Crossfire Detected
    Primary Display Resolution:  1920 x 1080
    Desktop Resolution: 1920 x 1080
    Primary Display Size: 10.87" x 6.14"  (12.48" diag)
                                            27.6cm x 15.6cm  (31.7cm diag)
    Primary Bus Type Not Detected
    Primary VRAM: 1024 MB
    Supported MSAA Modes:  2x 4x 8x
Sound card:
    Audio device: Speakers (Conexant SmartAudio H
Memory:
    RAM:  8082 Mb
Adobe Employee ,
Thanks so much for the detailed information. Could you please try reinstalling java once on your machine. Please let us know if this resolves your issue.
Ankit | Adobe AIR Engineering
Participant ,
Java Re-installation does not help. Strange is, that on my notebook with same Java version is packaging working fine.
d.
Adobe Employee ,
This issue is a weird issue and known to us with java version "1.8.0_112". Could you please check all the different JDK and JRE versions installed on your machine.
Please follow these steps:
1: Uninstall JRE and JDK and then reinstall them.
2. Please check environment variables as well.
We had faced similar issue which got resolved by following above mentioned steps. Please let us know how it goes.
Ankit
Participant ,
Unfortunately, nothing helps. Also it looks that Oracle is not providing access to older Java versions. I have AIR packaging working on both my work devices with Windows (7 and 10).. the problem is with our external worker, so it is hard to test in more details for me 😕 So far he can use AIR24 which is working without this issue.
Participant ,
Mar 01, 2017 Mar 01, 2017
Oldes :
You should uninstall JRE version 1.8.121 and install version 1.8.111
With 1.8.121 we have the following error when compiling on command line :
Unable to load a certificate in this file (our certificate is 1024-RSA)
With version 1.8.11 we have no DX tool issue or certificate issue.
By the way you guys at Adobe should report that bug about 1024-RSA issue with the latest version of Java JRE (1.8.121)
Adobe Employee ,
Hey,
Can you please recreate a certificate and try to use it for packaging? It might solve your problem for JRE 1.8.0_121 version as we are able to successfully package apps on this version.
Rohit
Adobe AIR Team
Participant ,
Cannot do this since the certificate is used on existing apps.
Mar 22, 2017 Mar 22, 2017
I have the same issue. Tried the jre/jdk libraries of 1.8.111 an 1.8.121 but cannot succeed. I cannot change the certiface of my apps since they are already published in play store. Any advice?
Mar 26, 2017 Mar 26, 2017
have the same issue, any one found a work around for this?
Adobe Employee ,
Mar 27, 2017 Mar 27, 2017
Hey warywarcry,
ADT Packaging should work fine with the older versions of Java. Is it possible for you to uninstall all the Java JRE and JDK versions and reinstall Java JRE 1.8.0_111 version?
Use this link to download older versions of Java 8. You need to create an account to be able to download the files.
Java Archive Downloads - Java SE 8
Please let us know if it helps.
Rohit
Adobe AIR Team
Hi Rohit,
Thanks for your reply. I followed your steps but nothing changed. I am installing the 32 bit version of Java to able to run FlashDevelop. Do you think it is the reason?
My java version;
java version "1.8.0_111"
Java(TM) SE Runtime Environment (build 1.8.0_111-b14)
Java HotSpot(TM) Client VM (build 25.111-b14, mixed mode)
Aug 18, 2018 Aug 18, 2018
Hey Rohit,
I am using latest AIR SDK 31 beta (have tried all sdks from 24 to 30 though). Using jre 1.8. Tried changing java path in adt.bat of AIR SDK (as suggested in one of the above comments). Still NO FIX. It still gives me dxtool failed error. However this happens only for SDK after 24 and only while publishing for Android. My apps publish perfectly for iOS with any AIR SDK. I need an immediate help on this as I need to upload my apps on Play Store and it has warned me to use version 26 and above for updating apps. Has anyone found any other solution to this problem?
Adobe Employee ,
Hey,
We are looking into this, we will keep you updated with the progress. There are two different issues which have been introduced with the java 1.8.0_112 and 1.8.0_121 versions.
1.8.0_112: dx command is failing due to process command execution failure
1.8.0_121: RSA-1024 Certificate issue
We are trying to fix these issues from our end.
Rohit
Adobe AIR Team
The problem is related with the 32 bit version of Java. I installed 64 bit  of JRE 1.8.0_111 and it packaged without problems. I suppose 64 bit JRE 1.8.0_121 will also work fine.
Apr 10, 2017 Apr 10, 2017
I continue with the problem after installing 64 bit of JRE 1.8.0_11. I remember the problem only happens for the builds on android or IOS, Desktop works! I wanted to test the AIR24 SDK version but I can not find it to download, I can only get the AIR25 SDK.
Adobe Employee ,
Apr 11, 2017 Apr 11, 2017
Hello lucasp,
You can download the previous Adobe AIR SDKs from Find and download archived versions of Adobe AIR SDK .
Adobe AIR Team
Guest
Mar 29, 2017 Mar 29, 2017
I have the same issue: dx tool failed: Result: 17
After updating to the latest version of AIR SDK 25 I can't package my app. I use Windows 7 x86 and JRE 1.8.111 x86.
May 03, 2017 May 03, 2017
Any progress for this problem? Tried AIR 26 beta same problem.
Also tried multiple java versions both 64bit and 32bit.
*Latest Facebook ANE from Distriqt requires AIR 25+
(Win 10 64bit, Flash Pro CS6)
/T
May 05, 2017 May 05, 2017
Same problem - "dx tool failed" with no further info when targeting Android after updating a project to AIR 25, no problems with AIR 23 (win 10 64bit, FlashDevelop). I (eventually) resolved it by using 64 bit java for packaging android and 32 bit java when targeting iOS - both are java 1.8.0_121
After uninstalling Java I can still create apk files from AIR 24 (without Java installed), am I missing something?
*No errors when packaging for iOS for AIR 25
May 06, 2017 May 06, 2017
Seems Animate CC fixed the problem for me, high time to abandon CS6 I guess
May 07, 2017 May 07, 2017
Make sure to keep CS6 installed, it can still do ActionScript 2, and Deco tool, and TLF. You may need to edit an old project some day. But yes, Animate has fixed or improved a lot of things.
