distance doesn't match after print
Participant ,
Feb 24, 2017 Feb 24, 2017
I was preparing a stationary recently, but there's something weird with the distances...
Inside of Indesign, it looks to be centered - exact same distance from the edges..
but when I print out the document and measure it in, the distance is quite a lot different.
Here's a screenshot that illustrates the issue:
The boxes are exactly the same size, the cm shown are what the real life distance is.
Why is this happening and what can I do about it ?
221
Community Expert , Feb 24, 2017 Feb 24, 2017
Or your printer might be misaligned. Check the printer manual to see how to correct it.
Is the width of the paper correct, or is it a bit short?
Mike Witherell
Participant ,
hm, that's a good question..
I just checked and it's 21 cm as it should be..
BarbBinder​
might also be possible. I'll try another printer if that helps..
Participant ,
ok, I guess this is the problem.
I just checked another printer and the difference in the distance is again different, and smaller.
So the printers must be misaligned. Should be ok if I send it to the printhouse.
Yes. You double checked your measurements so you will be fine.
