1 - create a circle
2 - I choose the tool "text on path"
3 - copy text (5-7 words) from clipboard
4 - freeeeezzzzzzzzzzzzzzzz......................
Anyone faced with similar?
There is a solution?
P.S. Windows 10, 64-bit; inDesign CC 2017 (last update)
Have you tried restoring your InDesign preferences? Here's how:
Trash, Replace, Reset, or Restore the application Preferences
I tried to recover....
I deleted all settings.....
did not help
BUT
when I create a circle and the text in a circle in InDesign CC 2014, and then open in InDesign CC 2017 cc - all working!!!!
If that doesn't work (trashing prefs), try re-ordering the workflow:
Based on your listed workflow it's crashing on Copy, so I'm putting that at the top to see if it makes a difference.
the problem is not a copy
I created a circle
select tool "text on path"
I clicked the mouse on the way - ooooops - freeez
I've had the same problem for a year or two now and can't figure it out either. I suspect it has something to do with paragraph styles, but I'm not sure exactly what.
i tried without styles
The result is the same
