Hello,
My Indesign cs6 mac Sierra started crashing on export to anything: pdf, jpeg, etc.
Previously it was working fine, just had got a bit sluggish lately, so a couple of times I rebooted InD on startup, which helped only for a while, and then it gets a bit slow again.
I work mainly on bookcovers, books, flyers, etc.
I have checked image names, making sure they have no spaces & so on.
I have exported the file as idml, it didn't work.
It is crashing when I try to export any file I open now...
Can anyone help me understand the crash report, and tell me how to go about fixing the problem/problems?
Thank you,
Ophelia
CS6 won't work for most people under Sierra. It was never tested with that operating system and, since it's considered end-of-life, it will never be fixed. You best bet is to upgrade to InDesign CC by getting a subscription. Or else you should roll back to an earlier operating system if possible.
Thank you, yes I have read that...
I was hoping that maybe I could stall a little longer.
I have also read that some people are having Sierra compatibility with CC also?
I suppose I'll try one last thing, check the compatibility of my fonts? I have added quite a few in the last couple of months.
Try this new concise guide:
Adobe InDesign CC 2017: troubleshooting how-to guide
It explains what to do when InDesign is crashing on export or print. Much of its advice is applicable to past versions.
Like (0) • Helpful • CommentActions
Thank you
