My website, www.BookAMagicShow.com refuses to center on my iPad pro or my pad mini. I have checked the sides and there is nothing overlapping. I have checked widgets, have made sure everything is responsive, but for some reason, the tablet still shows everything left of center leaving a space on the right side. It's driving me nuts!! Any help if possible!
Daniel
romanr89995466 написал(а)
On the tablet breakpoint, try to pin the objects to the center. Also they should have responsive width, or both width and height.
This site is not responsive, has no breakpoints and has no tablet layout. The first thing you need to look at the site, and then write a post.
oh and the site does center on my desktop!
Nevertheless, it is there, you just have not found it.
Well, do you think I didn't even open the site? It wasn't centered at all, at that time... If he doesn't have any tablet breakpoint, I think he should have... Even if he doesn't have responsive website. He can optimize the view for all devices better.
But anyway, the site is okey now.
I ended up adding a new breakpoint and that seemed to help..hopefully it works on all platforms for now until I can get in there and do the entire site responsive
I think Pavel is correct...your site works in landscape mode on iPad but not vertical. If you zoom out like Pavel shows it's hard to see things but it sure helps...you would be surprised what can be found ...little text boxes rectangles, etc. hard to see but if you do a select all you can find them.
