I have two catalogs, one containing video, and the other photos and I would like to merge them. Reading instructions on various sites, the easiest way is to open one catalog and use"import from another catalog" form the file menu. This bring in the correct files but all keywords and ratings are missing. Is there a way of merging two catalogs while maintaining all keywords?
First, let's try if an upgrade to the latest 2015.9 fixes the issue.
Hi ShawWellPete,
We have tried doing the same at our end. Imported couple of image from one to another catalog and its imported the keywords along with it, therefore you may need to check your workflow. refer: How to import photos from Photoshop Elements, other Lightroom catalogs, or apps such as iPhoto in Li...
You can export the keywords out from the first catalog and import into another, this may be sound stupid but you can this and check if that helps.
To export all exportable keywords from the catalog, choose Metadata > Export keywords, select a location for the keywords file, and then click Save
To import keywords into the catalog, choose Metadata > Import Keywords, navigate to and select the text file or catalog file containing keywords, and then click Open (Windows) or Choose (Mac OS)
Refer: How to use keywords in Lightroom
Mohit
Hi Mohit, thanks for taking the time to answer. This is very strange and there appears to be something with my catalog(s) that stops the correct process happening.
I have two portfolios that originally came from one, but the location of the content wasn't where I wanted it. I wanted all the video in one external drive and it was in all sorts of places. So I
1. selected all video files and exported them as a new catalog.
2. removed the video files from the original catalog
3. renamed both catalogs
4. organised the location of the video files in the video catalog
I then decided that having two catalogs is a bit of a pain so tried to reimport the video one into the photo one while leaving the files in the same location and the keywords and rating were not imported.
I have tried exporting the keywords from the video catalog and importing them into the photo one as you suggested and then importing the video catalog and it was the same as before. I have also tried just choosing a couple of videos when importing and the are imported without keywords or ratings.
any other suggestions?
nothing?
What is your exact version of LR and your OS?
Lightroom CC 2015.8 build 1099473
OS 10.2.3
Seems to be working fine now after the upgrade, thanks for your help!
