As an example, when you first open the Transform/Scale dialog the units in the width field is set to inches. If you change the units to pixels, do a scale change, then try to change the units back to inches the following glitch will show up. Clicking “inches" will set “Centimeters”. You have to click the second “pixels” to get “inches" Not a big problem once I realized what was happening.
I also see this on macOS Sierra 10.12.3 with photoshop CC 2017.0.1
Haven't been able to replicate on a win 10 system with same version of photoshop.
You can report the issue over here:
Try resetting your workspace.
This happens on two different machines and can be replicated 100% of the time. Did you try to see if you could replicate the issue? Photoshop 2017.0.1 OS X 10.11.6. BTW I did reset the workspace on one computer.
Is there a specific workspace you are using?
I using the exact same specs as you and have no problem.
I have experienced this issue with some drop downs in Dreamweaver in the past. Reseting or changing Workspaces has always corrected it in DW anyways. I have never experienced that in PS.
I restored to the Default workspace after you suggested it and it still does it. I looks ok when you first use the dropdown but if you switch it a couple times without exiting the tool the odd dropdown shows up. I had a specific reason to switch back and forth between pixels and inches during the use of the Transform/Scale without exiting and this CONSTSTIENTLY showed up. Clicking the second PIXEL would choose inches, clicking on INCHES would choose centimeters and on down the list. The list was "offset". Also, this exact behavior is on two machines. A 2012 iMac was just reformatted and restored not to long ago and the other is my 2015 iMac. Both machines running OS X 10.11.6. Thanks for you interest in this. I use Lightroom for 98% of my work and will probably not be doing anything that needs the multiple unit switching in transform again. I seems to work ok the FIRST time you enter the tool and switch units.
Thanks for confirming this issue so I know it is not my system/setup. I would make a bug report at "photoshop_family" but considering Adobes bug fixing record it is a waste of time.
Hi Bob
I just tried to replicate this and couldn't get it to happen I am using CC2017.0.1 on Windows 10 - are you using the same?
Dave
I am using 2017.0.1 on OS X 10.11.6 and it happens on two different 27inch iMacs. Its 100% repeatable. Its not a big problem once you know its displaying the dropdown incorrectly.
