Hello,
I'm having an issue in Photoshop cc 2017 where any time I click on the bar that you would click on in order to move a Photoshop window around it maximizes. An example would be imagine you have two Photoshop files open we'll call them File A and File B. Now let say you currently have File B active you're painting in it dodging burning ect.... now lets say you need to go to File A real quick for what ever reason. You go to click on the top bar of the File A window (one time) to activate it and bring it forward but it maximizes the window as if you had double clicked on the bar. Also if File A is maximized already and I'm working in File B and Click once to activate File A (the already maximized window) the file A window will de-maximize to the smaller option. So my question is how do i fix this\turn this off. lastly i know that you can maximize and de-maximize windows in most programs including Photoshop by double clicking the top bar but my issue is that it is maximizing when i click it only one time to activate a window that i need to work in. I've tested it and it only happens in Photoshop I've tried chrome and other programs and i don't have the issue. I've also used different mice and they all do it.
A little info
os: Windows 10
Photoshop cc 2017 most up to date as of Feb 10, 2017
Never had the issue until a few month ago and I've used Photoshop for years
I work with tabbing of windows turned off
File A and B are open. B is active.
need to work in File A so I Click on the File A bar ONE TIME only.
Immediately after clicking. The File A window maximizes.
How do I turn this off or fix it?
Thanks for the update,
Please try the steps below:-
If present, You can find this file in this location:-C:\Users\username\AppData\Roaming\Adobe\Adobe Photoshop CC 2017 folder.
Let us know if
...Copy link to clipboard
Hi PumaWhsiperer,
Please backup and then reset the current workspace you are working in. Have a look at Adobe Photoshop workspace basics
Akash
Thank you for your reply. I did as you said sadly it didn't fix the issue.
Have you updated Photoshop to the latest version CC 2017.0.1?
~Akash
Yes I have.
Please post the Photoshop Help>>Sytem info here so that we can verify the installed components.
Akash
System Info:
Adobe Photoshop Version: 2017.0.1 20161130.r.29 2016/11/30:23:00:00 CL 1099099 x64
Number of Launches: 5
Version: 10 or greater
System architecture: Intel CPU Family:6, Model:15, Stepping:2 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading
Physical processor count: 8
Logical processor count: 16
Processor speed: 2999 MHz
Built-in memory: 65462 MB
Free memory: 34386 MB
Memory available to Photoshop: 59527 MB
Memory used by Photoshop: 60 %
History Thumbnails: Enabled.
Touch Bar: Enabled.
Alias Layers: Disabled.
Modifier Palette: Enabled.
3D Multitone Printing: Disabled.
Highbeam: Enabled.
Image tile size: 1024K
Image cache levels: 4
Font Preview: Medium
TextComposer: Latin
OpenCL crashed on 11/8/2016 at 9:57:55 AM (Initializing Shared Sampling OpenCL feature)
Display: 1
Display Bounds: top=0, left=0, bottom=1080, right=1920
Display: 2
Display Bounds: top=0, left=-1920, bottom=1080, right=0
OpenGL Drawing: Enabled.
OpenGL Allow Old GPUs: Not Detected.
OpenGL Drawing Mode: Normal
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: True.
AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=1
NumNativeGPUs=0
glgpu[0].GLVersion="4.1"
glgpu[0].IsIntegratedGLGPU=0
glgpu[0].GLMemoryMB=4096
glgpu[0].GLName="NVIDIA GeForce GTX 960"
glgpu[0].GLVendor="NVIDIA Corporation"
glgpu[0].GLVendorID=4318
glgpu[0].GLDriverVersion="21.21.13.7254"
glgpu[0].GLRectTextureSize=16384
glgpu[0].GLRenderer="GeForce GTX 960/PCIe/SSE2"
glgpu[0].GLRendererID=5121
glgpu[0].HasGLNPOTSupport=1
glgpu[0].GLDriver="C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_b07608b795ac4102\nvd3dumx,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_b07608b795ac4102\nvwgf2umx,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_b07608b795ac4102\nvwgf2umx,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_b07608b795ac4102\nvwgf2umx,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_b07608b795ac4102\nvd3dum,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_b07608b795ac4102\nvwgf2um,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_b07608b795ac4102\nvwgf2um,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_b07608b795ac4102\nvwgf2um"
glgpu[0].GLDriverDate="20160811000000.000000-000"
glgpu[0].CanCompileProgramGLSL=1
glgpu[0].GLFrameBufferOK=1
glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.50 NVIDIA"
glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[65536]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
License Type: Subscription
Serial number: 91190962201580581333
GUIDBucket:
bucket: 211
test: DocumentPanel
Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\
Temporary file path: C:\Users\cbailey\AppData\Local\Temp\
Photoshop scratch has async I/O enabled
Scratch volume(s):
Startup, 232.4G, 47.7G free
Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\Plug-Ins\
Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\
Installed components:
A3DLIBS.dll A3DLIB Dynamic Link Library 9.2.0.112
ACE.dll ACE 2016/11/04-01:10:53 79.578171 79.578171
AdbePM.dll PatchMatch 2016/11/03:19:48:57 1.578146 1.578146
AdobeLinguistic.dll Adobe Linguisitc Library 10.0.0
AdobeOwl.dll Adobe Owl 5.2.11
AdobePDFL.dll PDFL 2016/08/10-16:53:20 79.195992 79.195992
AdobePIP.dll Adobe Product Improvement Program 7.4.1.60.45263
AdobeSVGAGM.dll AdobeSVGAGM 79.578171 79.578171
AdobeXMP.dll Adobe XMP Core 2016/09/14-01:09:01 79.159824 79.159824
AdobeXMPFiles.dll Adobe XMP Files 2016/09/14-01:09:01 79.159824 79.159824
AdobeXMPScript.dll Adobe XMP Script 2016/09/14-01:09:01 79.159824 79.159824
adobe_caps.dll Adobe CAPS 10,0,0,6
AGM.dll AGM 2016/11/04-01:10:53 79.578171 79.578171
ahclient.dll AdobeHelp Dynamic Link Library 2.0.0.2
AIDE.dll AIDE 2016/05/27-01:08:49 79.574279 79.574279
amtlib.dll AMTLib (64 Bit) 10.0.0.47 BuildVersion: 10.0; BuildDate: Thu Sep 1 2016 5:16:17) 1.000000
ARE.dll ARE 2016/11/04-01:10:53 79.578171 79.578171
AXE8SharedExpat.dll AXE8SharedExpat 2015/03/13-23:40:54 79.562390 79.562390
AXEDOMCore.dll AXEDOMCore 2015/03/13-23:40:54 79.562390 79.562390
Bib.dll BIB 2016/11/04-01:10:53 79.578171 79.578171
BIBUtils.dll BIBUtils 2016/11/04-01:10:53 79.578171 79.578171
boost_date_time.dll photoshopdva 10.0.0
boost_signals.dll photoshopdva 10.0.0
boost_system.dll photoshopdva 10.0.0
boost_threads.dll photoshopdva 10.0.0
cg.dll NVIDIA Cg Runtime 3.0.00007
cgGL.dll NVIDIA Cg Runtime 3.0.00007
CIT.dll Adobe CIT 2.1.0.1 2.1.0.1
CITThreading.dll Adobe CITThreading 2.1.0.1 2.1.0.1
CoolType.dll CoolType 2016/11/04-01:10:53 79.578171 79.578171
dnssd.dll Bonjour 3,0,0,2
dvaaudiodevice.dll photoshopdva 10.0.0
dvacore.dll photoshopdva 10.0.0
dvamarshal.dll photoshopdva 10.0.0
dvamediatypes.dll photoshopdva 10.0.0
dvametadata.dll photoshopdva 10.0.0
dvametadataapi.dll photoshopdva 10.0.0
dvametadataui.dll photoshopdva 10.0.0
dvaplayer.dll photoshopdva 10.0.0
dvatransport.dll photoshopdva 10.0.0
dvaui.dll photoshopdva 10.0.0
dvaunittesting.dll photoshopdva 10.0.0
dynamiclink.dll photoshopdva 10.0.0
ExtendScript.dll ExtendScript 2016/01/26-16:09:33 80.1060872 80.1060872
icucnv40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
icudt40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
icuuc40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
igestep30.dll IGES Reader 9.3.0.113
imslib.dll IMSLib DLL 10.0.0.1
JP2KLib.dll JP2KLib 2016/05/26-01:08:58 79.262945 79.262945
libifcoremd.dll Intel(r) Visual Fortran Compiler 10.0 (Update A)
libiomp5md.dll Intel(R) OpenMP* Runtime Library 5.0
libmmd.dll Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler 12.0
LogSession.dll LogSession 7.4.1.60.45263
mediacoreif.dll photoshopdva 10.0.0
MPS.dll MPS 2016/09/14-15:20:26 79.577269 79.577269
pdfsettings.dll Adobe PDFSettings 1.04
Photoshop.dll Adobe Photoshop CC 2017 18.0.1
Plugin.dll Adobe Photoshop CC 2017 18.0.1
PlugPlugExternalObject.dll Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit) 7.0.0
PlugPlugOwl.dll Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit) 7.0.0.67
PSArt.dll Adobe Photoshop CC 2017 18.0.1
PSViews.dll Adobe Photoshop CC 2017 18.0.1
SCCore.dll ScCore 2016/01/26-16:09:33 80.1060872 80.1060872
SVGRE.dll SVGRE 79.578171 79.578171
svml_dispmd.dll Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler 12.0
tbb.dll Intel(R) Threading Building Blocks for Windows 4, 4, 2016, 0412
tbbmalloc.dll Intel(R) Threading Building Blocks for Windows 4, 4, 2016, 0412
TfFontMgr.dll FontMgr 9.3.0.113
TfKernel.dll Kernel 9.3.0.113
TFKGEOM.dll Kernel Geom 9.3.0.113
TFUGEOM.dll Adobe, UGeom© 9.3.0.113
updaternotifications.dll Adobe Updater Notifications Library 10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME) 10.0.0.1
VulcanControl.dll Vulcan Application Control Library 5.3.0.16
VulcanMessage5.dll Vulcan Message Library 5.3.0.16
WRServices.dll WRServices Thu Jan 07 2016 04:50:10 Build 0.21960 0.21960
wu3d.dll U3D Writer 9.3.0.113
Required plug-ins:
3D Studio 18.0.1 (2017.0.1 x001 x003) - from the file “U3D.8bi”
Accented Edges 18.0.1 - from the file “Filter Gallery.8bf”
Adaptive Wide Angle 18.0.1 - from the file “Adaptive Wide Angle.8bf”
Angled Strokes 18.0.1 - from the file “Filter Gallery.8bf”
Average 18.0.1 (2017.0.1 x001 x003) - from the file “Average.8bf”
Bas Relief 18.0.1 - from the file “Filter Gallery.8bf”
BMP 18.0.1 - from the file “Standard MultiPlugin.8bf”
Camera Raw 9.8 - from the file “Camera Raw.8bi”
Camera Raw Filter 9.8 - from the file “Camera Raw.8bi”
Chalk && Charcoal 18.0.1 - from the file “Filter Gallery.8bf”
Chrome 18.0.1 - from the file “Filter Gallery.8bf”
Cineon 18.0.1 (2017.0.1 x001 x003) - from the file “Cineon.8bi”
Clouds 18.0.1 (2017.0.1 x001 x003) - from the file “Clouds.8bf”
Collada 18.0.1 (2017.0.1 x001 x003) - from the file “U3D.8bi”
Color Halftone 18.0.1 - from the file “Standard MultiPlugin.8bf”
Colored Pencil 18.0.1 - from the file “Filter Gallery.8bf”
CompuServe GIF 18.0.1 - from the file “Standard MultiPlugin.8bf”
Conté Crayon 18.0.1 - from the file “Filter Gallery.8bf”
Craquelure 18.0.1 - from the file “Filter Gallery.8bf”
Crop and Straighten Photos 18.0.1 (2017.0.1 x001 x003) - from the file “CropPhotosAuto.8li”
Crop and Straighten Photos Filter 18.0.1 - from the file “Standard MultiPlugin.8bf”
Crosshatch 18.0.1 - from the file “Filter Gallery.8bf”
Crystallize 18.0.1 - from the file “Standard MultiPlugin.8bf”
Cutout 18.0.1 - from the file “Filter Gallery.8bf”
Dark Strokes 18.0.1 - from the file “Filter Gallery.8bf”
De-Interlace 18.0.1 - from the file “Standard MultiPlugin.8bf”
Dicom 18.0.1 - from the file “Dicom.8bi”
Difference Clouds 18.0.1 (2017.0.1 x001 x003) - from the file “Clouds.8bf”
Diffuse Glow 18.0.1 - from the file “Filter Gallery.8bf”
Displace 18.0.1 - from the file “Standard MultiPlugin.8bf”
Dry Brush 18.0.1 - from the file “Filter Gallery.8bf”
Eazel Acquire 18.0.1 (2017.0.1 x001 x003) - from the file “EazelAcquire.8ba”
Entropy 18.0.1 (2017.0.1 x001 x003) - from the file “statistics.8ba”
Export Color Lookup Tables NO VERSION - from the file “Export3DLUT.8be”
Extrude 18.0.1 - from the file “Standard MultiPlugin.8bf”
FastCore Routines 18.0.1 (2017.0.1 x001 x003) - from the file “FastCore.8bx”
Fibers 18.0.1 - from the file “Standard MultiPlugin.8bf”
Film Grain 18.0.1 - from the file “Filter Gallery.8bf”
Filter Gallery 18.0.1 - from the file “Filter Gallery.8bf”
Flash 3D 18.0.1 (2017.0.1 x001 x003) - from the file “U3D.8bi”
Fresco 18.0.1 - from the file “Filter Gallery.8bf”
Glass 18.0.1 - from the file “Filter Gallery.8bf”
Glowing Edges 18.0.1 - from the file “Filter Gallery.8bf”
Google Earth 4 18.0.1 (2017.0.1 x001 x003) - from the file “U3D.8bi”
Graphic Pen 18.0.1 - from the file “Filter Gallery.8bf”
Halftone Pattern 18.0.1 - from the file “Filter Gallery.8bf”
HDRMergeUI 18.0.1 - from the file “HDRMergeUI.8bf”
HSB/HSL 18.0.1 - from the file “Standard MultiPlugin.8bf”
IFF Format 18.0.1 - from the file “Standard MultiPlugin.8bf”
IGES 18.0.1 (2017.0.1 x001 x003) - from the file “U3D.8bi”
Ink Outlines 18.0.1 - from the file “Filter Gallery.8bf”
JPEG 2000 18.0.1 - from the file “JPEG2000.8bi”
Kurtosis 18.0.1 (2017.0.1 x001 x003) - from the file “statistics.8ba”
Lens Blur 18.0.1 - from the file “Lens Blur.8bf”
Lens Correction 18.0.1 - from the file “Lens Correction.8bf”
Lens Flare 18.0.1 - from the file “Standard MultiPlugin.8bf”
Liquify 18.0.1 - from the file “Liquify.8bf”
Matlab Operation 18.0.1 (2017.0.1 x001 x003) - from the file “ChannelPort.8bf”
Maximum 18.0.1 (2017.0.1 x001 x003) - from the file “statistics.8ba”
Mean 18.0.1 (2017.0.1 x001 x003) - from the file “statistics.8ba”
Measurement Core 18.0.1 (2017.0.1 x001 x003) - from the file “MeasurementCore.8me”
Median 18.0.1 (2017.0.1 x001 x003) - from the file “statistics.8ba”
Mezzotint 18.0.1 - from the file “Standard MultiPlugin.8bf”
Minimum 18.0.1 (2017.0.1 x001 x003) - from the file “statistics.8ba”
MMXCore Routines 18.0.1 (2017.0.1 x001 x003) - from the file “MMXCore.8bx”
Mosaic Tiles 18.0.1 - from the file “Filter Gallery.8bf”
Multiprocessor Support 18.0.1 (2017.0.1 x001 x003) - from the file “MultiProcessor Support.8bx”
Neon Glow 18.0.1 - from the file “Filter Gallery.8bf”
Note Paper 18.0.1 - from the file “Filter Gallery.8bf”
NTSC Colors 18.0.1 (2017.0.1 x001 x003) - from the file “NTSC Colors.8bf”
Ocean Ripple 18.0.1 - from the file “Filter Gallery.8bf”
OpenEXR 18.0.1 - from the file “Standard MultiPlugin.8bf”
Paint Daubs 18.0.1 - from the file “Filter Gallery.8bf”
Palette Knife 18.0.1 - from the file “Filter Gallery.8bf”
Patchwork 18.0.1 - from the file “Filter Gallery.8bf”
Paths to Illustrator 18.0.1 - from the file “Standard MultiPlugin.8bf”
PCX 18.0.1 (2017.0.1 x001 x003) - from the file “PCX.8bi”
Photocopy 18.0.1 - from the file “Filter Gallery.8bf”
Photoshop 3D Engine 18.0.1 (2017.0.1 x001 x003) - from the file “Photoshop3DEngine.8bi”
Photoshop Touch 14.0 - from the file “PSDX.8bi”
Picture Package Filter 18.0.1 (2017.0.1 x001 x003) - from the file “ChannelPort.8bf”
Pinch 18.0.1 - from the file “Standard MultiPlugin.8bf”
Pixar 18.0.1 (2017.0.1 x001 x003) - from the file “Pixar.8bi”
Plaster 18.0.1 - from the file “Filter Gallery.8bf”
Plastic Wrap 18.0.1 - from the file “Filter Gallery.8bf”
PLY 18.0.1 (2017.0.1 x001 x003) - from the file “U3D.8bi”
PNG 18.0.1 - from the file “Standard MultiPlugin.8bf”
Pointillize 18.0.1 - from the file “Standard MultiPlugin.8bf”
Polar Coordinates 18.0.1 - from the file “Standard MultiPlugin.8bf”
Portable Bit Map 18.0.1 (2017.0.1 x001 x003) - from the file “PBM.8bi”
Poster Edges 18.0.1 - from the file “Filter Gallery.8bf”
PRC 18.0.1 (2017.0.1 x001 x003) - from the file “U3D.8bi”
Radial Blur 18.0.1 - from the file “Standard MultiPlugin.8bf”
Radiance 18.0.1 (2017.0.1 x001 x003) - from the file “Radiance.8bi”
Range 18.0.1 (2017.0.1 x001 x003) - from the file “statistics.8ba”
Render Color Lookup Grid NO VERSION - from the file “Export3DLUT.8be”
Reticulation 18.0.1 - from the file “Filter Gallery.8bf”
Ripple 18.0.1 - from the file “Standard MultiPlugin.8bf”
Rough Pastels 18.0.1 - from the file “Filter Gallery.8bf”
Save for Web 18.0.1 - from the file “Save for Web.8be”
ScriptingSupport 18.0.1 - from the file “ScriptingSupport.8li”
Shake Reduction 18.0.1 - from the file “Shake Reduction.8bf”
Shear 18.0.1 - from the file “Standard MultiPlugin.8bf”
Skewness 18.0.1 (2017.0.1 x001 x003) - from the file “statistics.8ba”
Smart Blur 18.0.1 - from the file “Standard MultiPlugin.8bf”
Smudge Stick 18.0.1 - from the file “Filter Gallery.8bf”
Solarize 18.0.1 (2017.0.1 x001 x003) - from the file “Solarize.8bf”
Spaces 18.0.1 - from the file “Spaces.8li”
Spatter 18.0.1 - from the file “Filter Gallery.8bf”
Spherize 18.0.1 - from the file “Standard MultiPlugin.8bf”
Sponge 18.0.1 - from the file “Filter Gallery.8bf”
Sprayed Strokes 18.0.1 - from the file “Filter Gallery.8bf”
Stained Glass 18.0.1 - from the file “Filter Gallery.8bf”
Stamp 18.0.1 - from the file “Filter Gallery.8bf”
Standard Deviation 18.0.1 (2017.0.1 x001 x003) - from the file “statistics.8ba”
STL 18.0.1 (2017.0.1 x001 x003) - from the file “U3D.8bi”
Sumi-e 18.0.1 - from the file “Filter Gallery.8bf”
Summation 18.0.1 (2017.0.1 x001 x003) - from the file “statistics.8ba”
Targa 18.0.1 - from the file “Standard MultiPlugin.8bf”
Texturizer 18.0.1 - from the file “Filter Gallery.8bf”
Tiles 18.0.1 - from the file “Standard MultiPlugin.8bf”
Torn Edges 18.0.1 - from the file “Filter Gallery.8bf”
Twirl 18.0.1 - from the file “Standard MultiPlugin.8bf”
U3D 18.0.1 (2017.0.1 x001 x003) - from the file “U3D.8bi”
Underpainting 18.0.1 - from the file “Filter Gallery.8bf”
Vanishing Point 18.0.1 - from the file “VanishingPoint.8bf”
Variance 18.0.1 (2017.0.1 x001 x003) - from the file “statistics.8ba”
Virtual Reality Modeling Language | VRML 18.0.1 (2017.0.1 x001 x003) - from the file “U3D.8bi”
Water Paper 18.0.1 - from the file “Filter Gallery.8bf”
Watercolor 18.0.1 - from the file “Filter Gallery.8bf”
Wave 18.0.1 - from the file “Standard MultiPlugin.8bf”
Wavefront|OBJ 18.0.1 (2017.0.1 x001 x003) - from the file “U3D.8bi”
WIA Support 18.0.1 (2017.0.1 x001 x003) - from the file “WIASupport.8li”
Wind 18.0.1 - from the file “Standard MultiPlugin.8bf”
Wireless Bitmap 18.0.1 (2017.0.1 x001 x003) - from the file “WBMP.8bi”
ZigZag 18.0.1 - from the file “Standard MultiPlugin.8bf”
Optional and third party plug-ins: NONE
Duplicate and Disabled plug-ins: NONE
Plug-ins that failed to load: NONE
Extensions:
Google Photos 1.0.4 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\com.henrikstabell.googlephotos\index.html”
com.adobe.inapp.purchase 2.7.122 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\purchase.html”
Recent Files 1.4.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.ccx.start\index.html”
Libraries 2.7.122 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\index.html”
Start 1.4.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.ccx.start\index.html”
Export As 3.0.8 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html”
DODGE AND BURN 2.0 2.0.4 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\com.thinkingpixels.dodgeandburn2\index.html”
com.adobe.preview.loader 1.3.1 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSLoader\loader.html”
New Document 1.4.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.ccx.start\fnft.html”
PixelSquid 0.7.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\com.pixelsquid.heroplayer\index.html”
com.adobe.experimentation.extension 2.0.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.experimentation.extension\index.html”
Adobe Color Themes 6.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.KulerPanel.html\index.html”
Device Preview 1.3.1 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSPanel\panel.html”
Installed TWAIN devices: NONE
A long-time (yet seldom-mentioned) Windows shortcut is that double-clicking a title bar will Maximize the window (or Restore it, depending on the current state), and sounds like that is what is happening with your floating windows. Until you solve the "I am clicking once but Photoshop is registering a double-click", you might try the tabbed interface: Window > Arrange > Consolidate All to Tabs.
You might not like it as much as your floating windows at first, but you won't get that behavior unless you click the main title bar.
Thanks for the reply!
I've thought about going back to tabs, but I'm holding out on it cause I feel it slows my work flow down quite a bit. That being said I may just suck it up and do it cause this double click issue can be quite annoying at times.
You are very welcome. As a user like you, I can't fix Photoshop, of course—just offer alternatives—but you already have Adobe staff member Akash Sharma on the thread, which is great if it ends up being a Photoshop issue.
I know you said you switched out the mouse, but is the current mouse driver up to date? It sounds more like a mouse issue (or some other conflict), as I haven't ever seen this come up on this forum before. You might google your mouse and photoshop to see if others have run with your set up have run into the same issue.
I actually didn't think to check for a driver update....Just updated my mouse, it's a logitech G602, and sadly the problem persists.
I have tried replicating the issue with other programs from google chrome to 3ds max to regular old windows explorer, and none of them exhibit a single mouse click registering as a double click. That along with the fact that other mice(mouses?) produce the same result makes me think that it is a photoshop issue.
Well, the good news is that you can keep working for now.
If you figure out the solution on your own, it would be helpful to me (and others reading this thread) if you could come back and let us know what was going on.
Happy Monday.
I definitely will.
Happy Monday you as well.
Thanks, BarbBinder for your helpful inputs.
Could you please try restoring Photoshop preferences following the steps below:-
Note: Using this keyboard shortcut, preference files for custom shortcuts, workspaces, and color settings will also be reset to default.
Let us know if that helps
~Akash
Sadly this did not fix it either. The windows still maximize with a single mouse click.
Let us know if that helps.
~Akash
Akash, you are the man!!!
Changing ports didn't work but renaming the tw0001.dat to tw0001.dat.OLD did the trick.
Before you go off into the night to help other distressed photoshop users. Do you by any chance know why this issue came up in the first place, because I had been using photoshop normally for a long time then one day this all started happening.
MANY THANKS!!!
Yay!!
Glad to know it is working now.
This issue started in Ps CC 2015 and is limited to only a few users.This file is linked with an extension that is required to run Photoshop. We will check if we can prevent creation of this .dat file in the future updates.
Akash
I wanted to let you know that I have had this same problem for over a year, and your solution worked for me--renaming tw0001.dat to tw0001.dat.OLD . What a relief!
