I am using a simple contact form, placed inside a Tooltip composition widget.
The ReCaptcha 2.0 does not work. The circle just turns and turns forever. If I copy the form outside the composition widget, it works right away.
I have created a simple test page that shows both versions side by side:
Does anyone know how to fix this? For now, I have simply disabled the ReCaptcha in the actual contact form, but that is hardly a long term solution.
There is also a secondary issue: when I test the form on an iPhone 5S, the ReCaptcha isn't displayed at all. Ideas?
Thanks for your suggestions!
Best regards,
Stéphane
Hey Stéphane,
This won't work because Recaptcha is itself coded in form of an iframe.
And embedding an iframe within another iframe won't allow the re-captcha code to work.
Although, I liked your concept of embedding a form in a tooltip, but you may take it as a limitation of Muse for now.
Ankush
Hey Stéphane,
Ankush
Thanks for your answer, Ankush!
So if I want to include the ReCaptcha, I should try another way of achieving the same effect. Do you have any suggestions?
You may give a try to lightbox widget and see if ReCaptcha works there.
