I worked on two compositions in separate After Effects files (a 6 second and a minute composition). How can I merge the compositions in a new composition so that the minute long composition will follow immediately after the 6 second composition?
okay
There are many ways here are a few. I suggest going with the first method.
https://forums.adobe.com/people/Mike+Gondek2 wrote
render out each composition to a format such as .mp4, and then import each into a new composition
Disagree with this part. You do not want to render to a compressed format like MP4 and then continue working on it. Render to a proper mezzanine codec (intermediate codec, production codec, whatever you want to call it). Something like QuickTime with the PNG codec, Cineform, DNxHD, etc.
Here is how I would do it:
That's it.
I disagree with all you're methodes. The easiest is:
1. If the compositions are finished save them
2. After wich you change the composition settings here you need to change the end timing tot your end time do this for both compositions.
3. Save them both again.
4. Create a new project.
5. Select import drop down menu and select the file option
6. Now import both *.aep files, they will show up as folders
7. Create a new composition and import the old compositions from the folders in After Affects (can be achieved by drag and dropping)
Oh my gosh your method was so much easier! thank you!!
this is the best method here. The other suggestions are... well I don't have anything good to say about them.
it's a very basic thing in AE, inport the 6 sec project inside the one minute project and create a new comp 1 min and 6 sec thane drag both comps inside your new comp
