Hi again
If you used the "Next 5 slides" preview, that would certainly
explain it. This is because only enough of the project is compiled
to present the next 5 slides. If you have a link that points beyond
the next 5 slides, that link will fail because that part of the
project wasn't factored in.
If you used a preview that included the whole project, the
link should work. You may preview the entire project either in
Captivate or in the Web browser. You don't have to publish to see
your work. Previewing should be sufficient. But you do need to
consider the type of preview you use.
Another type of preview that regularly nails folks is the
"Play this slide". This type of preview is only good for getting a
feel for when objects appear or disappear. There is no
interactivity possible.
Hopefully this helps a bit... Rick
