When I import layers into AE the bounding box changes. I have a circle and the bounding box goes past the circle.
I imported layers into AE from Illustrator, I did composition retain layer size.
What I am aiming to do is rotate the circle in it's center point, the issue is when I import the layer into AE the bounding box is off from what it is in Illustrator and because of this when I rotate the circle in AE it comes of as wobbly.
Here is what the layer looks like when I double tap it.
I made sure that all of my bounding boxes are constrained in Illustrator by expanding each individual layer and then making a clipping mask over the group.
When I import this layer into AE the bonding box is extended on the right side of the circle and I do not know how to fix this issue.
This is what happens when I render it and that wobbly look that I dont like: https://www.behance.net/gallery/49312953/WORK-PLAY-STICKER-SET
Help is appreciated
I can't see anything wobbly, but since you haven't attached the actual images nor provided any info about critical things like comp settings, render settings etc., this is a moot point. We could speculate all day and still not figure it out. Start by checking things li9ke comp pixel aspect ratio and the relevant preview functions, then look for unwanted scaling issues and all that...
Mylenium
Just drag you screenshots into the reply field on the forum or use print screen and paste. EZ as pie. Without seeing what you are seeing we can't give you better advice than Mylenium already has. This is not a known bug.
Hi mizzlecizzleyup,
We didn't hear back from you. Did you ever solve this problem? Please tell us how you did that if you don't mind, or do you still need help?
Kevin
