Hello...
First time posting in this forum, I can't seem to find an answer to this problem I'm having in any forums here and elsewhere. I have the plug-in InData that I import from an excel text file into a prototype in an InDesign document that I use daily. I have created layers for different "backs" that I keep static (except for the text I import). The problem I'm running into is that I don't know how to change the layer names except to manually change them. Is there a script that will change the form numbers automatically? The form number the layers need to be is actually in the text file that I import. Maybe in Applescript somehow to script change layer 1 to layer 15... (or any number.. to form 1234 to 5678... Any help would be greatly appreciated. InDesign CS6 v8.0.. Thank you!
Are you able to extract a concordance list as, e.g.:
Layer_1 >> Layer_12
Layer_2 >> Layer_23
Layer_3 >> Layer_39
Could you be clearer ? Not sure I get the idea here.
Hi
Can you be clearer about what you want to achieve, especially why you need so many different layers?
If there is no specific reason to have that huge amount of layers, maybe you could use another import method, such as "merging data"?
Merge data to create form letters, envelopes, or mailing labels in Adobe InDesign
I need the layers as I copy & paste into many documents that utilize my end product. I use the "remember layers" and that is why it would be very helpful to have these layers change automatically to coincide with the list from the excel spreadsheet. This list will change with every import. I'm a newbie to scripting and find these forums very helpful but have no idea how to get it to work. I apologize for the confusion.
It's easy to rename layers via scripting, but as Obi suggests you would need to feed a script the names. So this AppleScript asks for a comma delimited list:
Renames the layers top to bottom:
tell application "Adobe InDesign CS6"
set {t, AppleScript's text item delimiters} to {AppleScript's text item delimiters, {","}}
display dialog "Layer List (comma delimited no spaces)" default answer ""
set myList to text items of (text returned of the result)
set AppleScript's text item delimiters to t
set l to every layer of active document
repeat with i from 1 to count of l
try
set name of item i of l to item i of myList
end try
end repeat
end tell
I will give this a try!
This works great, I'll just have to rework my layers to begin top to bottom as I work bottom to top. It's not perfect abut workable. Thank you!
The script can be altered to name the layers from the bottom up:
set n to 1
repeat with i from (count of l) to 1 by -1
try
set name of item i of l to item n of myList
set n to n + 1
end try
end repeat
end tell
I have added a 3rd story to my prototype with the list of form numbers that I can paste into the display dialog that pops up but how do I get a dialog box to display the list that I'm importing? The display comes up with "Layer List" but without the actual list of forms.
set myTemplate to ((path to desktop as Unicode text) & "5W National Flyerbacks:NationalBack_5W.indd")
set myData to ((path to desktop as Unicode text) & "5W National Flyerbacks:5Wbacks.txt")
tell application id "com.Adobe.InDesign"
set user interaction level of script preferences to never interact
set myDocument to open myTemplate
import data from file myData into story "story 1" using prototype story "proto 1"
import data from file myData into story "story 2" using prototype story "proto 2"
import data from file myData into story "story 3" using prototype story "proto 3"
display dialog "layer List"
set user interaction level of script preferences to interact with all
set myDelims to AppleScript's text item delimiters
set AppleScript's text item delimiters to "."
set myPath to (text item 1 of myData)
try
end try
end repeat
end tell
export document 1 format PDF type to (myPath & ".pdf") without showing options
set AppleScript's text item delimiters to myDelims
end tell
It isn't clear to me what you are trying to do.
Looks like the list of names you want to use as layer names is somewhere in the file 5Wbacks.txt?
Yes, that is correct, (import for proto 3 contains only the list of form numbers) - I want to display the list of names so that I can copy and paste into the display box that changes the layer names. Then if possible delete my prototype layer from the document.
You would have to open the text file and get the list. So this script would get the text from a file named Text.txt and display a dialog with the text:
set myText to text of (read POSIX file "/Users/username/Desktop/Text.txt")
display dialog myText
So this would get the layer names from a text file, but a lot could go wrong—the file can't have anything other than the comma delimited list, and the path has to be exactly right.
set myData to ((path to desktop) & "5W National Flyerbacks:5Wbacks.txt") as string
set pp to (the POSIX path of myData)
set myText to text of (read POSIX file pp)
tell application "Adobe InDesign CC 2014"
set myList to text items of myText
set n to 1
try
set n to n + 1
end try
end repeat
end tell
Thank you, this is not something I'm familiar with. I'll try this until I get it.. 🙂 Thanks so much for your help.
Hi Shirley,
Thanks for your help with this script. Is there a way to select (say 75 layers) and not have to type in 75 names in to get them to change. Say, any code that will change the name and add consecutive numbers at the end of it?
Peter
