Hello,
I'm having a rendering problem with After Effects CC 2015. When I try to render my composition which is 10 seconds long, it just stops after 1 second. I've also come across 2 instances where it said it was user stopped when I didn't touch anything. I would appreciate it if you guys could help me.
Nobody can tell you anything without exact system info or other technical details like exacxt render settings, comp settings, details about the comp contents. Start by flushing the cache and check for potentially critical things like audio files, damaged footage sources, whacked out effects etc..
Mylenium
My render settings are the standard settings After Effects sets up for me, I'll post a screenshot of everything including my comp settings and render settings with this reply.
That blank error screen is popping up with some frequency lately. Try uninstalling CC 2017 and reinstalling, but don't let it update to 14.1 (if it gives you the choice). That might help.
What version of AE are you using that actually launches? 13.xx.xx?
In addition to the things Mylenium has asked - and we really do need to know more information to help you - I can make a suggestion.
Try opening your project in CC 2017 and see if it renders.
But if that doesn't work, please give us more information!
I'll try this, I'll get back on if it worked!
I remember why I didn't use CC 2017 in the first place. I get this thing. When I open CC 2017, I get this window and just nothing happens.
The blank error screen bug in CC 2017 should be fixed in the update that released today. See Tim's post about it here. The After Effects CC 2017 update to version 14.2 is rolling out worldwide. It may take a day or so to show up for you depending on where you live. You also may need to log out and back in to your CC app or other funky things to get it to show up.
Please let us know if this works for you.
