Metadata with Elements catalogue to Lightroom
Feb 28, 2017 Feb 28, 2017
I am new to Lightroom while I had been using Elements 13 for years.  I had just started to use the LR and try to import the catalogue from Elements.  Around 1000 pics was successfully import.  However, I found that most of the pictures imported does not contain the metadata including the capture date and time.  I tried the function to copy the XMP from files.  But the action was hung with the status bar stopped moving.
Just want to see if this is a common issue and how I could get over this without manual update the files.
760
Adobe Employee ,
Hi gtiger,
You can turn off the Graphics processor from the Lightroom preferences and then start the import.
Open Lightroom > Edit menu > Preferences > Performance tab > Uncheck the GPU.
Also, refer the below link for the correct workflow.
How to import photos from Photoshop Elements, other Lightroom catalogs, or apps such as iPhoto in Li...
Mohit
Mar 01, 2017 Mar 01, 2017
I made the change and use the "File-> Import from Elements Catalogue" to perform the import.  Then the import stopped at 0% of Merging Photos.  Any reason?
I am running on a MacBook Pro in MacOS 10.12
Please explain the steps you used to do this. Give us details.
Please know that the default operation of Elements is to NOT write metadata to XMP, and unless you specifically told Elements to write the metadata to XMP, then the metadata is not there.
Once I import the catalogue, I did select "Metadata-> Read from files" to try updating the metadata from the original files.  But the status bar does not move.
Mar 02, 2017 Mar 02, 2017
How did you import the catalog? What was the exact sequence of steps?
I open a new catalogue in LR and then select 'File->Import from Elements Catalogue'
Wilkin Moy
You are not the first person to report that Import from Elements Catalog doesn't work as expected. I don't know why this happens.
Are these photos from a camera or a scanner?
If you didn't have Elements write the metadata to the photo file, then the Lightroom command File->Read Metadata from Files will not help.
My photos were taken from camera and iPhone as well.  I did compare the metadata on Elements and LR where imported.  The data on LR is missing in somehow.  Is there any log we may check the issues on LR?
Mar 03, 2017 Mar 03, 2017
No there is no log. The only suggestion I can give you is to try the import again. Otherwise, if it still doesn't work, then as far as I know, it's not going to work as is. You might want to use Elements to write the metadata to the files before importing into Lightroom, then try the Lightroom command Metadata->Read Metadata from Files
Truly I did try remove the catalogue in LR and import again in a brand new one. In this case, I think I should stay using Elements.
Wilkin Moy
You're not going to try my last suggestion?
I just tried it and still not getting the capture date as before.
