I hope this is the right place to get support?
Software:
Operating System: Windows 7 Enterprise 64Bit-DE.Hardware:
We use Acrobat in our Company on some Computers. For Instance since one of the last, from Adobe automatically installed Updates (unknown), we have Problems with the right-mouse-button Property-menue (or direct click on object->popup-menues / see picture). they dissappears after some actions.
Problem: The Popup-Menues are lost or exists no longer (missing)! After...
In this screenshot-area you can see a created popup-menue from which I talk:
(normaly it pops up when you click at the object in the PDF or rmb-click) - this popups disappears as above described...
How are the menus implemented? Would you be able to share some files that show this behavior? We would need the original files and instructions about how to recreate the problem.
Hallo,
our Software creates automatically this popups. This is: Mentor Graphics, the Schematic Tool called "DxDesigner", Version VX2.1.
I created a Zipfile file for you (7z) and it contains 2 sample pdf-files. In "DemoSchemTest.pdf" are the popups.
But how to upload here a file? I just find "Bild einfügen" (insert Picture).
You can upload the file to cloud.acrobat.com and share the link.
Ich bekomme leider immer nur das angezeigt auf der cloud.acrobat.com... (wird also noch dauern bis ich was hochladen kann)
There were global problems yesterday with some cloud apps because of a shutdown of the AWS servers. Try it again...
it's still the same... the cloud is not available
Clear the cache and the cookies of the browser or use a other browser.
Try refreshing the page. It should be working fine now...
Nope
I tried it now with IE, Chrome and Firefox and on three different Computers. Each the same. after Login on cloud.Acrobat.com -> nix geht mehr.
Ich denke ich werde das Problem jetzt an unsere IT übergeben. Vielleicht können die auf diese Seite zugreifen!
Use Google Drive or Dropbox...
On Thu, Mar 2, 2017 at 1:35 PM, jürgenh20574902 <forums_noreply@adobe.com>
before I proceed here,.. is this the official Support from Acrobat?
What if we have at anytime confidential data?
No, this is not the official Adobe support. Most users here are users of Adobe's technology, just like you. Anything you post here is public.
But how to get official Support? There Homepage is not easy to navigate (in this way).
http://helpx.adobe.com/contact.html (don't use any of the "Forum" options, otherwise you will end up here again)
Be warned: You're going to have to pay a lot of money for official support with scripting issues.
Here are some instructions about how to share a link using Adobe's Document Cloud: Share Documents via Adobe's Document Cloud - KHKonsulting LLC
You might also use ZIP instead, more people can read it easily...
It would be pointless to contact support as you do not have anything that is supported.
Reader is free - no support.
Acrobat X is End-of-life - no support.
Perhaps we could help you if you could manage to upload a file. These menus do not look like any standard or usual thing, so we need to know how they are made.
It looks like the result of a call to the JS methods popUpMenu or popUpMenuEx...
Thanks, these methods seem little used so I was not familiar with what their results looked like. Maybe more standard than I thought. But we still need a file.
okay, before I proceed here, I contact the Support from the other Software.
First I thought it can only be an Acrobat patch, because of when I merge the error occurs, else not!. But who knows.
The last update of Acrobat X was in the year 2015.
Ja das schließt Acrobat zunächst aus. Die Ursachen können jetzt in .net oder sonstigen Windows Updates liegen, aber natürlich auch an der Erstellungs-Quelle oder Adobe Reader -Updates am System, Dll's werden oft geteilt (shared).
Egal jetzt, an der Stelle kann der Post eigentlich auch geschlossen werden. Ich versuche anderweitig Support zu erhalten.
So, to take a step back, what happens when two PDF files containing form fields are combined? Certainly some things may be lost according to how you merge. For example inserting and replacing pages will do different things. You presented this as being about the menus, but have you checked form fields in general? And document level scripts? Are document level scripts used?
