I only had the option to change the "ppi" - no dpi. Is that the same thing?
No, it's not.
You most probably want to change the image resolution. This is measured in PPI (pixels per inch). If someone told you to change the DPI, then they just used the wrong terminology.
I just want to make a correction to this old message.
The number 72 (concerning ppi/dpi) has nothing to do with refresh rate in Hz.
Old screens used to have this "density" of pixels (72 pixels per inch, ppi). There is one story (that might very well be true) about Apple building a monitor (their old style... with a built-in computer) with the same resolution as their printer (72 dots per inch, dpi), to make the printed image the same size as the image on screen when viewed in 100% zoom.
It's just a preset. A print shop that knows anything about an image file has no problems printing a perfectly fine copy from an image set to 72 ppi/dpi (ppi translates to screen, dpi to printers but it roughly means the same thing, I would say). One problem might be that your image will come out very BIG, unless the printshop has changed the print size to a certain format.
For the quality, the only important thing is that you've got enough pixels in your image (not the pixels per inch setting).
Locking this old thread. If you need further help with Illustrator, please start a new discussion
