I have an issue with the pngs in a file.
I did everything in a pc, but when I opened the "fla" file in a mac (to export the ipa), it loaded older version of the png images. Not all images, only some of them were different.
Is there something I can do?
you're welcome.
p.s. that could be an animate issue. it can do funky things like that, but it's still more likely user error.
if you mean png files in the library changed when moving the fla from a pc to a mac, you moved the wrong fla.
if you mean something else, explain.
This is exactly what I mean.
It's the right file. I already tried to saved as another file and this is still happening..
right click a problematic bitmap in your library>click properties>actionscript and take a screenshot of the bitmap properties panel.
Sorry that it took me a while to reply you, I was way for a few days.
Here is the screenshot of the image, nothign is selected. Any thoughts what it may be?
i suspect, but don't know that it's, user error.
Well, thank you. I'll probably have to review all images before publishing.
you're welcome.
