Hi:
I installed latest Photoshop Update and now PS does not save under regular "Save" nor under "Save As". Rest of funtionality withing app works. Any help appreciated
So what happens? Do you get the Save/Save As... dialog? If so post a screenshot so we can examine it.
How to take and post screenshots.
That's the thing, nothing happens it just doesn't work. Everything else works including option to print, but when you want to save no saving dialog window, no saving progress back
Let's go with a Preferences Reset. Let me know if that works for you or not. Restart your Mac to be sure.
thanks!
will try that nolw
Did as you recommended but although I have to say that booting time was fast and save dialogue worked this time, app became unresponsive at 79 % progress. See Pic
Can you go to Help > System Info and click on the Copy button? Then paste the results (Edit > Paste in your browser) in your reply?
Thanks for your reply,
Here's the sys info:
Adobe Photoshop Version: 2017.0.1 20161130.r.29 2016/11/30:23:00:00 CL 1099099 x64
Number of Launches: 0
Operating System: Mac OS 10.12.3
System architecture: Intel CPU Family:6, Model:94, Stepping:3 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2
Physical processor count: 4
Processor speed: 3200 MHz
Built-in memory: 32768 MB
Free memory: 20573 MB
Memory available to Photoshop: 30411 MB
Memory used by Photoshop: 70 %
History Thumbnails: Enabled.
Touch Bar: Enabled.
Alias Layers: Disabled.
Modifier Palette: Disabled.
3D Multitone Printing: Disabled.
Highbeam: Enabled.
Image tile size: 1024K
Image cache levels: 4
Font Preview: Medium
TextComposer: Latin
RelaxedOpenCL crashed on 2/27/17 at 8:59:24 PM (Initializing OpenCL features with relaxed OpenCL requirements)
Display: 1
Main Display
High DPI Monitor
Display Bounds: top=0, left=0, bottom=1440, right=2560
OpenGL Drawing: Enabled.
OpenGL Allow Old GPUs: Not Detected.
OpenGL Drawing Mode: Advanced
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: True.
AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=1
NumCLGPUs=1
NumNativeGPUs=1
glgpu[0].GLVersion="2.1"
glgpu[0].IsIntegratedGLGPU=0
glgpu[0].GLMemoryMB=2048
glgpu[0].GLName="AMD Radeon R9 M380 OpenGL Engine"
glgpu[0].GLVendor="ATI Technologies Inc."
glgpu[0].GLVendorID=4098
glgpu[0].GLRectTextureSize=16384
glgpu[0].GLRenderer="AMD Radeon R9 M380 OpenGL Engine"
glgpu[0].GLRendererID=16915460
glgpu[0].HasGLNPOTSupport=1
glgpu[0].CanCompileProgramGLSL=1
glgpu[0].GLFrameBufferOK=1
glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.20"
glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[16384]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[128]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
clgpu[0].CLPlatformVersion="1.2 (Jan 4 2017 22:35:59)"
clgpu[0].CLDeviceVersion="1.2 "
clgpu[0].IsIntegratedCLGPU=0
clgpu[0].CLMemoryMB=2048
clgpu[0].CLName="AMD Radeon R9 M380 Compute Engine"
clgpu[0].CLVendor="AMD"
clgpu[0].CLVendorID=16915456
clgpu[0].CLDriverVersion="1.2 (Jan 10 2017 22:25:08)"
clgpu[0].CLBandwidth=5.97541e+10
clgpu[0].CLCompute=441.853
nativegpu[0].NativeName="AMD Radeon R9 M380"
License Type: Subscription
Serial number: 96040872293490309613
GUIDBucket:
bucket: 160
test: ReduceUXFriction
Application folder: /Applications/Adobe Photoshop CC 2017/
Photoshop scratch has async I/O enabled
Scratch volume(s):
Startup, 930.4G, 199.0G free
Required Plug-ins folder: /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/
Primary Plug-ins folder: /Applications/Adobe Photoshop CC 2017/Plug-ins/
Installed components:
AdbePM.framework AdbePM 2.5.00.377243 1.578146
adobe_caps.framework adobe_caps 10.0.0.6 1.584361
AdobeACE.framework AdobeACE 2.20.02.37447 79.578171
AdobeAGM.framework AdobeAGM 4.30.60.37447 79.578171
AdobeAXE8SharedExpat.framework AdobeAXE8SharedExpat 3.8.0.34320 79.562390
AdobeAXEDOMCore.framework AdobeAXEDOMCore 3.8.0.34320 79.562390
AdobeBIB.framework AdobeBIB 1.2.03.37447 79.578171
AdobeBIBUtils.framework AdobeBIBUtils 1.1.01 79.578171
AdobeCoolType.framework AdobeCoolType 5.15.00.37447 79.578171
AdobeCrashReporter.framework AdobeCrashReporter 7.3.2
AdobeExtendScript.framework AdobeExtendScript 4.5.6.4 80.1060872
AdobeJP2K.framework AdobeJP2K 1.2.2.36529 79.262945
AdobeLinguistic.framework 21429
AdobeMPS.framework AdobeMPS 5.8.1.37174 79.577269
AdobeOwl.framework AdobeOwl 5.2.11
AdobePDFL.framework AdobePDFL 15.0.0.36975 79.195992
AdobePDFSettings.framework AdobePDFSettings 1.4
AdobePIP.framework AdobePIP 7.4.1.60.45263
AdobeScCore.framework AdobeScCore 4.5.6.4 80.1060872
AdobeSVGAGM.framework AdobeSVGAGM 1.0.0.37447 79.578171
AdobeSVGRE.framework AdobeSVGRE 6.0 79.578171
AdobeUpdater.framework AdobeUpdater 6.0.0.1452 "52.338651"
AdobeXMP.framework AdobeXMPCore 79.159824 79.159824
AdobeXMPFiles.framework AdobeXMPFiles 79.159824 79.159824
AdobeXMPScript.framework AdobeXMPScript 79.159824 79.159824
ahclient.framework ahclient 2.0.0.1
AIDE.framework AIDE 1.5.0.36540 79.574279
aif.framework aif 6.0.00.1 1.
amtlib.framework amtlib 10.0.0.47
boost_date_time.framework boost_date_time 10.0.0.0
boost_filesystem.framework boost_filesystem 10.0.0.0
boost_signals.framework boost_signals 10.0.0.0
boost_system.framework boost_system 10.0.0.0
boost_threads.framework boost_threads 10.0.0.0
Cg.framework NVIDIA Cg
CIT.framework
CITThreading.framework
dvaaudiodevice.framework dvaaudiodevice 10.0.0.0
dvacore.framework dvacore 10.0.0.0
dvamarshal.framework dvamarshal 10.0.0.0
dvamediatypes.framework dvamediatypes 10.0.0.0
dvametadata.framework dvametadata 10.0.0.0
dvametadataapi.framework dvametadataapi 10.0.0.0
dvametadataUI.framework dvametadataUI 10.0.0.0
dvaplayer.framework dvaplayer 10.0.0.0
dvatransport.framework dvatransport 10.0.0.0
dvaui.framework dvaui 10.0.0.0
dvaunittesting.framework dvaunittesting 10.0.0.0
dynamiclink.framework dynamiclink 10.0.0.0
ICUConverter.framework ICUConverter 3.61 "gtlib_6.0" "." "21287"
ICUData.framework ICUData 3.61 "gtlib_6.0" "." "21287"
ICUUnicode.framework ICUUnicode 3.61 "gtlib_6.0" "." "21287"
LogSession.framework LogSession 7.4.1.60.45263
manta.framework manta 2.0.00.1 1.
mediacoreif.framework mediacoreif 10.0.0.0
PlugPlugExternalObject.framework 7.0.0.67
PlugPlugOwl.framework PlugPlugOwl 7.0.0.67
UpdaterNotifications.framework UpdaterNotifications 10.0.0.1 "10.0.0.1"
WRServices.framework WRServices 12.0.0 12.0.0.1000
Required plug-ins:
3D Studio 18.0.1 ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
Accented Edges 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Adaptive Wide Angle 18.0.1, Copyright © 2014-2016 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
Alien Skin Blow Up 3 Blow Up 3 3.1.0.140 34640 Copyright (c) 2016 Alien Skin Software, LLC - from the file “Alien Skin Blow Up 3 Automation.8li.plugin”
Alien Skin Exposure X2 Autolayer Autolayer 2.0.0.400 35085 Copyright © 2012 Alien Skin Software, LLC - from the file “Alien Skin Exposure X2 Autolayer.8li.plugin”
Alien Skin Snap Art 4 Autolayer Autolayer 4.1.0.136 34641 Copyright © 2012 Alien Skin Software, LLC - from the file “Alien Skin Snap Art 4 Autolayer.8li.plugin”
Angled Strokes 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Average 18.0.1 ©1993-2016 Adobe Systems Incorporated - from the file “Average.plugin”
Bas Relief 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Blow Up Blow Up 3 3.1.0.140 34640 Copyright (c) 2016 Alien Skin Software, LLC - from the file “Alien Skin Blow Up 3 Photoshop.8bf.plugin”
BMP 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Camera Raw 9.8 (692), Copyright © 2016 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
Camera Raw Filter 9.8 (692), Copyright © 2016 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
Chalk & Charcoal 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Chrome 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Cineon 18.0.1 ©2002-2016 Adobe Systems Incorporated - from the file “Cineon.plugin”
Clouds 18.0.1 ©1993-2016 Adobe Systems Incorporated - from the file “Clouds.plugin”
Collada DAE 18.0.1 ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
Color Halftone 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Colored Pencil 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
CompuServe GIF 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Conté Crayon 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Craquelure 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Crop and Straighten Photos 18.0.1 Copyright © 2003-2016 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
Crop and Straighten Photos Filter 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Crosshatch 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Crystallize 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Cutout 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Dark Strokes 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
De-Interlace 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Dicom 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “dicom.plugin”
Difference Clouds 18.0.1 ©1993-2016 Adobe Systems Incorporated - from the file “Clouds.plugin”
Diffuse Glow 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Displace 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Dry Brush 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Eazel Acquire 18.0.1 Copyright © 2007-2016 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
Entropy 18.0.1 ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
Export Color Lookup Tables 18.0.1 Copyright ©2012-2016 Adobe Systems Incorporated - from the file “Export3DLUT.plugin”
Exposure X2 Exposure X2 2.0.0.400 35085 Copyright (c) 2016 Alien Skin Software, LLC - from the file “Alien Skin Exposure X2 Photoshop.8bf.plugin”
Extrude 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
FastCore Routines 18.0.1 ©1990-2016 Adobe Systems Incorporated - from the file “FastCore.plugin”
Fibers 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Film Grain 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Filter Gallery 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Flash 3D 18.0.1 ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
Fresco 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Glass 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Glowing Edges 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Google Earth 4 KMZ 18.0.1 ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
Graphic Pen 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Halftone Pattern 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
HDRMergeUI 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
HSB/HSL 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
IFF Format 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
IGES 18.0.1 ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
Ink Outlines 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
JPEG 2000 18.0.1 Copyright © 2001-2016 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
Kurtosis 18.0.1 ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
Lens Blur 18.0.1, Copyright © 2002-2016 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
Lens Correction 18.0.1, Copyright © 2002-2016 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
Lens Flare 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Liquify 18.0.1, Copyright © 2001-2016 Adobe Systems Incorporated - from the file “Liquify.plugin”
Matlab Operation 18.0.1 ©1993-2016 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
Maximum 18.0.1 ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
Mean 18.0.1 ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
Measurement Core 18.0.1 Copyright © 1993-2016 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
Median 18.0.1 ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
Mezzotint 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Minimum 18.0.1 ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
MMXCore Routines 18.0.1 ©1990-2016 Adobe Systems Incorporated - from the file “MMXCore.plugin”
Mosaic Tiles 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Multiprocessor Support 18.0.1 Copyright © 1990-2016 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
Neon Glow 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Note Paper 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
NTSC Colors 18.0.1 ©1993-2016 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
Ocean Ripple 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
ON1 Develop 2017 11.0.1 (ON1 Photo Raw 2017), Copyright © 2017 ON1. All rights reserved. - from the file “ON1 Develop 2017-suite.plugin”
ON1 Develop 2017 Filter 11.0.1 (ON1 Photo Raw 2017), Copyright © 2017 ON1. All rights reserved. - from the file “ON1 Develop 2017-suite.plugin”
ON1 Effects 10 10.5.1 (ON1 Photo 10), Copyright © 2016 ON1. All rights reserved. - from the file “ON1 Effects 10-suite.plugin”
ON1 Effects 10 Filter 10.5.1 (ON1 Photo 10), Copyright © 2016 ON1. All rights reserved. - from the file “ON1 Effects 10-suite.plugin”
ON1 Effects 2017 11.0.1 (Suite 11), Copyright © 2017 ON1. All rights reserved. - from the file “ON1 Effects 2017-suite.plugin”
ON1 Effects 2017 Filter 11.0.1 (Suite 11), Copyright © 2017 ON1. All rights reserved. - from the file “ON1 Effects 2017-suite.plugin”
ON1 Enhance 10 10.5.1 (ON1 Photo 10), Copyright © 2016 ON1. All rights reserved. - from the file “ON1 Enhance 10-suite.plugin”
ON1 Enhance 10 Filter 10.5.1 (ON1 Photo 10), Copyright © 2016 ON1. All rights reserved. - from the file “ON1 Enhance 10-suite.plugin”
ON1 Portrait 10 10.5.1 (ON1 Photo 10), Copyright © 2016 ON1. All rights reserved. - from the file “ON1 Portrait 10-suite.plugin”
ON1 Portrait 10 Filter 10.5.1 (ON1 Photo 10), Copyright © 2016 ON1. All rights reserved. - from the file “ON1 Portrait 10-suite.plugin”
ON1 Resize 10 10.5.1 (Suite 10), Copyright © 2016 on1. All rights reserved. - from the file “ON1 Resize 10-suite.plugin”
ON1 Resize 10 Engine Automation 10.5.1 (Suite 10), Copyright © 2016 on1. All rights reserved. - from the file “ON1 Resize 10-suite.plugin”
ON1 Resize 10 Engine Filter 10.5.1 (Suite 10), Copyright © 2016 on1. All rights reserved. - from the file “ON1 Resize 10-suite.plugin”
ON1 Resize 10 Filter 10.5.1 (Suite 10), Copyright © 2016 on1. All rights reserved. - from the file “ON1 Resize 10-suite.plugin”
ON1 Resize 2017 11.0.1 (Suite 11), Copyright © 2017 on1. All rights reserved. - from the file “ON1 Resize 2017-suite.plugin”
ON1 Resize 2017 Engine Automation 11.0.1 (Suite 11), Copyright © 2017 on1. All rights reserved. - from the file “ON1 Resize 2017-suite.plugin”
ON1 Resize 2017 Engine Filter 11.0.1 (Suite 11), Copyright © 2017 on1. All rights reserved. - from the file “ON1 Resize 2017-suite.plugin”
ON1 Resize 2017 Filter 11.0.1 (Suite 11), Copyright © 2017 on1. All rights reserved. - from the file “ON1 Resize 2017-suite.plugin”
OpenEXR 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Paint Daubs 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Palette Knife 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Patchwork 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Paths to Illustrator 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
PCX 18.0.1 ©1989-2016 Adobe Systems Incorporated - from the file “PCX.plugin”
Photocopy 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Photoshop 3D Engine 18.0.1 ©2006-2016 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
Photoshop Touch Copyright ©2013-2016 Adobe Systems Incorporated - from the file “PSDX.plugin”
Picture Package Filter 18.0.1 ©1993-2016 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
Pinch 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Pixar 18.0.1 ©1989-2016 Adobe Systems Incorporated - from the file “Pixar.plugin”
Plaster 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Plastic Wrap 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
PLY 18.0.1 ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
PNG 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Pointillize 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Polar Coordinates 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Portable Bit Map 18.0.1 ©1989-2016 Adobe Systems Incorporated - from the file “PBM.plugin”
Poster Edges 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
PRC 18.0.1 ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
Radial Blur 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Radiance 18.0.1 ©2003-2016 Adobe Systems Incorporated - from the file “Radiance.plugin”
Range 18.0.1 ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
Render Color Lookup Grid 18.0.1 Copyright ©2012-2016 Adobe Systems Incorporated - from the file “Export3DLUT.plugin”
Reticulation 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Ripple 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Rough Pastels 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Save for Web 18.0.1, Copyright © 1999-2016 Adobe Systems Incorporated - from the file “Save for Web.plugin”
ScriptingSupport 18.0.1, Copyright © 2016 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
Shake Reduction 18.0.1, Copyright © 2014-2016 Adobe Systems Incorporated - from the file “Shake Reduction.plugin”
Shear 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Skewness 18.0.1 ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
Smart Blur 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Smudge Stick 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Snap Art 4 Snap Art 4 4.1.0.136 34641 Copyright (c) 2016 Alien Skin Software, LLC - from the file “Alien Skin Snap Art 4 Photoshop.8bf.plugin”
Solarize 18.0.1 Copyright © 1993-2016 Adobe Systems Incorporated - from the file “Solarize.plugin”
Spaces 18.0.1, Copyright © 2015 Adobe Systems Incorporated - from the file “Spaces.plugin”
Spatter 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Spherize 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Sponge 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Sprayed Strokes 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Stained Glass 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Stamp 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Standard Deviation 18.0.1 ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
STL 18.0.1 ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
Sumi-e 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Summation 18.0.1 ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
Targa 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Texturizer 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Tiles 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Torn Edges 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Twirl 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
U3D 18.0.1 ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
Underpainting 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Vanishing Point 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
Variance 18.0.1 ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
Virtual Reality Modeling Language | VRML 18.0.1 ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
Water Paper 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Watercolor 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Wave 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Wavefront|OBJ 18.0.1 ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
Wind 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Wireless Bitmap 18.0.1 ©1989-2016 Adobe Systems Incorporated - from the file “WBMP.plugin”
ZigZag 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Optional and third party plug-ins:
Analog Efex Pro 2 2.0.12.10, Copyright ©2000-2015, Google - from the file “/Applications/Adobe Photoshop CC 2017/Plug-ins/Google/Analog Efex Pro 2/Analog Efex Pro 2.plugin/”
BackgroundFilter 2.2.21.10, Copyright ©2000-2014, Google - from the file “/Applications/Adobe Photoshop CC 2017/Plug-ins/Google/Dfine 2/BackgroundFilter.plugin/”
Color Efex Pro 4 4.3.24.10, Copyright ©2000-2015, Google - from the file “/Applications/Adobe Photoshop CC 2017/Plug-ins/Google/Color Efex Pro 4/Color Efex Pro 4.plugin/”
Dfine 2 2.2.21.10, Copyright ©2000-2014, Google - from the file “/Applications/Adobe Photoshop CC 2017/Plug-ins/Google/Dfine 2/Dfine2.plugin/”
FineStructuresFilter 2.2.21.10, Copyright ©2000-2014, Google - from the file “/Applications/Adobe Photoshop CC 2017/Plug-ins/Google/Dfine 2/FineStructuresFilter.plugin/”
HDR Efex Pro 2 2.2.24.10, Copyright ©2000-2015, Google - from the file “/Applications/Adobe Photoshop CC 2017/Plug-ins/Google/HDR Efex Pro 2/HDR Efex Pro 2.plugin/”
HotPixelsFilter 2.2.21.10, Copyright ©2000-2014, Google - from the file “/Applications/Adobe Photoshop CC 2017/Plug-ins/Google/Dfine 2/HotPixelsFilter.plugin/”
Merge to HDR Efex Pro 2 2.2.24.10, Copyright ©2000-2015, Google - from the file “/Applications/Adobe Photoshop CC 2017/Plug-ins/Google/HDR Efex Pro 2/HDR Efex Pro 2 Automation.plugin/”
Nik Collection Selective Tool 2.1.28.10, Copyright ©2000-2015, Google - from the file “/Applications/Adobe Photoshop CC 2017/Plug-ins/Google/Selective Tool/SelectivePalette.plugin/”
ShadowsFilter 2.2.21.10, Copyright ©2000-2014, Google - from the file “/Applications/Adobe Photoshop CC 2017/Plug-ins/Google/Dfine 2/ShadowsFilter.plugin/”
Sharpener Pro 3: (1) RAW Presharpener 3.1.21.10, Copyright ©2000-2014, Google - from the file “/Applications/Adobe Photoshop CC 2017/Plug-ins/Google/Sharpener Pro 3/SHP3RPS.plugin/”
Sharpener Pro 3: (2) Output Sharpener 3.1.21.10, Copyright ©2000-2014, Google - from the file “/Applications/Adobe Photoshop CC 2017/Plug-ins/Google/Sharpener Pro 3/SHP3OS.plugin/”
Silver Efex Pro 2 2.2.24.10, Copyright ©2000-2015, Google - from the file “/Applications/Adobe Photoshop CC 2017/Plug-ins/Google/Silver Efex Pro 2/Silver Efex Pro 2.plugin/”
SkinFilter 2.2.21.10, Copyright ©2000-2014, Google - from the file “/Applications/Adobe Photoshop CC 2017/Plug-ins/Google/Dfine 2/SkinFilter.plugin/”
SkyFilter 2.2.21.10, Copyright ©2000-2014, Google - from the file “/Applications/Adobe Photoshop CC 2017/Plug-ins/Google/Dfine 2/SkyFilter.plugin/”
StrongNoiseFilter 2.2.21.10, Copyright ©2000-2014, Google - from the file “/Applications/Adobe Photoshop CC 2017/Plug-ins/Google/Dfine 2/StrongNoiseFilter.plugin/”
Viveza 2 2.1.21.10, Copyright ©2000-2014, Google - from the file “/Applications/Adobe Photoshop CC 2017/Plug-ins/Google/Viveza 2/Viveza2.plugin/”
Duplicate and Disabled plug-ins: NONE
Plug-ins that failed to load: NONE
Extensions:
Retouching tools 1.3.0 - from the file “/Users/andy/Library/Application Support/Adobe/CEP/extensions/RetouchTools/index.html”
com.adobe.inapp.purchase 2.7.122 - from the file “/Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/CEP/extensions/com.adobe.DesignLibraryPanel.html/purchase.html”
Recent Files 1.4.0 - from the file “/Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/CEP/extensions/com.adobe.ccx.start/index.html”
Libraries 2.7.122 - from the file “/Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/CEP/extensions/com.adobe.DesignLibraryPanel.html/index.html”
Start 1.4.0 - from the file “/Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/CEP/extensions/com.adobe.ccx.start/index.html”
ON1 1.0.0 - from the file “/Library/Application Support/Adobe/CEP/extensions/onOne/index.html”
Blendit 1.0.0 - from the file “/Users/andy/Library/Application Support/Adobe/CEP/extensions/Blendit/index.html”
Export As 3.0.8 - from the file “/Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/CEP/extensions/com.adobe.photoshop.crema/PSPanel/dialog.html”
Lumenzia 2.0.8 - from the file “/Users/andy/Library/Application Support/Adobe/CEP/extensions/com.lumenzia.ext/index.html”
com.adobe.preview.loader 1.3.1 - from the file “/Library/Application Support/Adobe/CEP/extensions/com.adobe.previewHD/PSLoader/loader.html”
Ultimate Retouch 2.0.0 - from the file “/Users/andy/Library/Application Support/Adobe/CEP/extensions/UltimateRetouch/index.html”
New Document 1.4.0 - from the file “/Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/CEP/extensions/com.adobe.ccx.start/fnft.html”
com.adobe.experimentation.extension 2.0.0 - from the file “/Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/CEP/extensions/com.adobe.experimentation.extension/index.html”
Adobe Color Themes 6.1.0 - from the file “/Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/CEP/extensions/com.adobe.KulerPanel.html/index.html”
Device Preview 1.3.1 - from the file “/Library/Application Support/Adobe/CEP/extensions/com.adobe.previewHD/PSPanel/panel.html”
Basics 1.3.1 - from the file “/Users/andy/Library/Application Support/Adobe/CEP/extensions/com.lumenziabasics.ext/index.html”
Installed TWAIN devices: NONE
Sorry for the late reply. I took a look at your system info and see many plugins and extensions. some plugins I see don't look like they have been updated for CC 2017. In fact one thing when Photoshop upgrades is that it does not copy plugins over.
So I think the next step is to hunt down or update those errant plugins.
More details on this:
Photoshop plug-ins troubleshooting
Let me know if that helps.
Additional troubleshooting steps. http://blogs.adobe.com/crawlspace/2012/07/photoshop-basic-troubleshooting-steps-to-fix-most-issues.h...
You may want to install a prior version of Photoshop to get some work done. How to do that is covered in the above link.
I always keep an extra version handy in case of unexpected behavior. You definitely don't want downtime.
I followed your recommendation. I uninstalled plugins from Photoshop. I deleted them from Library as well. I uninstalled Creative suite and reinstalled it in a different user on my computer to start fresh. Photoshop did work for a little while but is back again to same issue of not saving, saving as or closing tab. Now, I did follow your other recommendation of downloading a previous version of PS and it works as a charm but it's not compatible with current Camera raw 9.8 which I need to handle my RAF raw files. What do I do? I don't shoot JPGs.
Any and all help is appreciated.
All versions of Photoshop CC can run ACR 9.8 Just because the version it shipped with is earlier than 9.8 does not mean you can't update it.
Two ways to get it: From the Creative Control Desktop panel, look for the cog in the upper right corner and from the dropdown menu, choose "check for updates". CC2015.5 should then have an "Update" button.
Or Help > Updates in CC 2015.
Well, in theory it should work like that. Here's what's happening on my end. If I go Help>Updates it takes me straight to CC Desktop panel, there's no option for update under the cog wheel for PS CS6 ( See Screen Capture ). Also if I go to Library>Adobe>Plugins>CS6>File Formats>Camera Raw.plugin it shows the version installed is 7.0 not 9.8. Now when I try to install Latest Camera Raw version 9.8 it does install but only to CC and not CS6. Is there any way/bypass where I can install Camera Raw 9.8 on PS CS6? If that would be the case I'd be happy, CS6 has everything I need and doesn't crash but useless because I can't work my files. Again thanks!
Sorry I'm late, but I had to run some errands. In any case here is what's going on:
CS6 will only go up to Camera Raw 9.1.1 because Adobe stopped it there and so you can't install 9.8.
But using the DNG Converter, you can batch convert your Raws to DNG format and they will open up in 9.1.1
You should not have 7.0 in CS6, but if it won't update, move that plugin outside the folder and then open CS6 and from the Help menu, run Updates.
After 9.1.1 is in verified as the current ACR plugin, then get the DNG converter here:
Adobe Digital Negative Converter 9.x download DNG 9.8 and follow the instructions included in this help document.
Raws should be placed in a folder and batch converted.
Let me know how it went.
Gene
