How to get rid of hidden folders
Guide ,
Mar 02, 2017 Mar 02, 2017
I need to report if the link folder contains any subfolder or not. The below coding is working fine but in some files it shows some folder names but when i see the parent link folder then it is not visible. How to ignore the hidden folders. Is it the method i used is correct? Because some times it show the result wrongly.
var inputFolder = Folder(app.activeDocument.allGraphics[0].itemLink.filePath).parent;
var fileList = inputFolder.getFiles();
var myArray=[]
flag=0;
for(i=0;i<fileList.length;i++){
var myfile=fileList;
    if(myfile.name==".DS_Store") continue;
    if((myfile instanceof Folder) && (!myfile.hidden)){
        myArray.push(myfile);
        if(myArray.length>0){flag=1;}
if(flag==1){alert("ERROR: Some SubFolder(s) present in the Link Folder. "+ "Name and Path of SubFolder(s)\n"+decodeURI(myArray.join("\n")))}
if(flag==0){alert("No SubFolder(s) present in the Link Folder")}
Also is it any other method we can use to achieve my need?
K
Scripting
235
Mar 03, 2017 Mar 03, 2017
Hm.
Maybe it would help to check the name with a RegExp like that:
Don't know if that is sufficient.
At least all files and folders on OSX with a name beginning with a dot are invisible.
Uwe
Guide ,
Thanks Uwe, i will try and let you know.
Hi Kartik,
it's not perfect at all.
This is only finding files and folders with a dot in the beginning of a name.
But there are also folders around—e.g. in the root folder of a system harddisk—where other folders without the dot in the file name are not visible to the user. Maybe you look better after an AppleScript based solution.
Uwe
Guide ,
Hi Laubender,
Yes i also had a thought about getting solution from Applescript. Because it gives better results in order searching for Mac related things.
But unfortunately i dont have knowledge in Applescript.
K
