When I open an image in camera raw and select the gradient tool or the oval tool and move my curser into the image mouse click and hold I only get the hand not the ability to draw a gradient. I have also tried this in Bridge and get the same results. All software is up to date.
It appears that updating to the latest Wacom Into drivers did the trick. I was only on version behind but the install fixed the issue. I noticed that when using the tablet when I pressed the Hand key nothing happened. At first I tried just unplugging the tablet but that had no effect so I did the driver update. Thanks for all the support.
Hi Philp,
May I know which version of Photoshop are you using and on which operating system?
Did you try pressing the spacebar?
Sahil
Sahil,
Thank you for replying,
Mac OX 10.12.2
Photoshop CC 2017.0.1.20131130.r.29
Space bar makes no difference
Phil Pape
[Private info removed]
