hi
i'm looking for an auto crop boders script or action
i guess the script should be better because the border depth could change images by images
i have searched in the forum without luck
there are several programs like irfanview or xnview that can do it , but i would like to do with photoshop
i own several photos with borders white / black or other colors
would really glad to use a photoshop
i'm running mostly photoshop 2015 and 2014 ,but i have installed 2017 too , windows 10 pro 64bit
i use pixel and cm as units
thanks
I have some question about your problem.
1. Do you have cropping size?
2. Do you have guideline for image?
hi
the cropping size is very often different
and about guidelines, no i haven't them
thanks
Try this script.
The one for photoshop cs.
http://www.melor.com/projects/autocrop_info.htm
You could also try File>Automate>Crop and Straighten Photos.
hi
it doesn't works , at least on all the photos i have tried
about autocrop , i tried the 3 options, it works on the second or third execution
in short i have to run the script twice or 3 times at least
but it's very old
is there nothing new?
thanks
Could you show us an example of the kind of image your dealing with?
Have you tried Image>Trim?
hi
yes i have tried the trim
i guess i can't upload the image , just because it's personal , i should find a different image
by the way , they are the borders , loaded in photoshop , screenshots taken with the image loaded in photoshop
Are you trying to crop out the thin white boarder?
Hi R_Kelly
yes i did
just looking for a script to process several photos at once
