Using LR and PS cloud versoin on an HP Specter laptop. Several of the screens cannot be adjusted for size. Example is when Exporting a file from LR (as a jpeg) the screen is so large that I cannot reach the download icon at the bottom of the screen. Ctrl + and - do nothing.
Set your screen resolution to the Native setting. Then you can Scale the screen up with another section of the Display options.
You have changed the Base resolution to make the fonts and like larger. That has thrown off the sizing of dialog boxes.
If you move your curser to the top of the dialog box, does it turn into a double arrow so that you can drag the top edge downward and reduce the size of the box? You should then be able to move the entire box upward to see the Export button.
No, I had tried that to enlarge the screen, but it's as high as it goes. I
am having trouble with LR and PS, and interestingly, also with MPix. I
wish that I never had to change from a Mac to a PC.
James J. Hackett
Director of Development
The Parkes Development Group
The Parkes Companies.
j <jimhackett8@gmail.com>hackett@parkescompanies.com
Phone 561-308-5246
Jim Hackett
561-308-5246
On Sun, Mar 5, 2017 at 10:53 AM, JoeKostoss <forums_noreply@adobe.com>
