I have just properly installed InDesign after finishing the free trial, and now for some reason when I try and save/export any documents I've made it stops responding and I have to shut it down. The documents are being recovered automatically when I open it back up, but I'm getting frustrated and confused with it because it's worked fine until now and as soon as I actually pay for InDesign it ceases to function. I need this to work for a uni assignment, please help!
Tell us a little more about your setup:
Hi
I'm not familiar with some of the language, but I'm using the most recent version of the MacBook Air so whatever Apple products use.
It's the Indesign CC.
I'm just trying to save to my MacBook desktop so I have a .pdf version of both documents, so a local drive. I've just tried and it's allowing me to publish online but not save.
Yeah I've just installed it today after the trial ran out and I clicked add license.
File > Save is used to save the InDesign (.indd) file.
File > Export is used to create a copy of the .indd file as a .pdf file.
Which one isn't working? And did it work before you added the license?
Neither of the save or export options are working, the program freezes for a couple seconds and then the little colour wheel pops up to indicate it's loading but nothing happens and I have to force quit. I've also noticed now as well that it won't let me perform certain functions like adding text boxes or placing images.
Export and save worked fine before the license was added.
I would try two different things:
1.) Trash Preferences:
Troubleshooting 101: Replace, or "trash" your InDesign preferences
then
2.) InDesign > Preferences > Advanced Type and disable Type Contextual Controls
Come back and let us know if this makes a difference.
Thank you, it's letting me click 'Save' it now, but still exporting isn't working. Also when I got to 'Save As...' it's still not working.
Just to confirm, you did both of the steps listed above?
After that try saving to a different folder.
And is it all files that you are not able to save or is it just one file that is missed behaving?
I have just tried to follow the steps again that you outlined and when trying to open InDesign back up and open the book that was saved it's crashing again so now I can't actually view anything. I'm at my wit's end with this. I'm trying to retrieve the document and it's not there now????? I'm getting really angry about this, I can't afford for this to all of a sudden pack it in.
I have no doubt you're feeling angry about this. I would be feeling the same way.
I have never seen InDesign delete a file off the hard drive so I'm hopeful that it is still there. The priority now is to locate the file and put a copy in another folder, or better yet on another drive. Is InDesign saying anything about a recovery file?
It was before I followed those instructions, but now when I opened it up it doesn't say anything about recovering the file. I made sure to save the file before I shut InDesign down but it's not listed in any recent files.
The link I just gave you shows you how to navigate to the folder with the recovery files.
I've been able to locate the files and have them saved to my desktop now and on a USB just in case. But I still can't place any new images/export/save as... anything. Would you be able to offer a plan B?
Phew!! Ok, back to the software.
Here are are my thoughts:
Fiona—are you able to save your files again?
Hi Barbinder I am having exactly the same problem!
I've gone through all the steps above and still wasn't able to save the recovered document. Every time I open back Indesign it recovers my document but when trying to export a PDF or save the InDesign file it gives me the saving spinner and stays there forever. When I go to Force Quit it shows "InDesign not responding".
Is there anything else I can try to solve this?
Thanks - really appreciate your help!!
But you can reopen the file? That's a good start. Did you try saving it under a new name? Or as IDML, and then close it and reopen it and save it back as an INDD?
~Barb
