Locked
adobe draw application for ipad
Feb 20, 2017 Feb 20, 2017
I have used the Adobe Draw application on 2 different ipads (one very new and one older) and every time that I open the application then it crashes.  Is there a problem with the application or my ipad? How can I open it so that I can use it without crashing?
555
Adobe Employee ,
Feb 28, 2017 Feb 28, 2017
Hi Danielle,
Is the application crashing on both your devices?
Also if you can share the OS details of your ipads, it will be helpful.
Sheena
Yes it crashes on both iPads however I'm only using the newer one now. Below is the info for my iPad.
Danielle
http://pinterest.com/dinrab/
Adobe Employee ,
Mar 01, 2017 Mar 01, 2017
Hi Danielle,
Thanks for confirming. However, I don't see the OS details in your reply.
Kindly confirm me the OS version only of the iPad device.
Also, have you tried to uninstall and reinstall the application on your device?
Just in case if you haven't, try the steps below:
1. Uninstall the application
2. Reboot your Device
3. Reinstall the application from the App Store.
Let me know if that helps!
Sheena
My OS is 10.2.1 on my iPad.
I have tried to reinstall and the same issue occurs.
Danielle Rabinowitz
graphic designer & brand stylist
<Removed by Moderator>
Adobe Employee ,
Mar 02, 2017 Mar 02, 2017
Hi Danielle,
Our design apps require a lot of processing power and memory, there could be a possibility that the crashings is related to this only.
Could you please check the amount of storage on your device which is free and the speed/age of the processor?
Sheena
Sheena,
I'm having the same issue. The app keeps crashning or freezing on multiple devices. I've reinstalled repeatedly, done hard restarts and processing bandwidth is not an issue. All software is up to date and all devices are new or relatively so.
Any other suggestions? Very frustrated!
Thx
Adobe Employee ,
Hi Sarah,
Can you write to me through the in-app feedback so I can see all your device information (it's pulled automatically when email is sent through the app). To do that tap Settings. Then Send Feedback.
Sue.
Sue,
Done.
3 main problems:
- app tosses me out (started this am was working fine before 9:30 EST. CN see that the app is trying to load info (spinning wheel in top left corner) but eventually gives up and throws me out.
- on reinstall after hard restart I can briefly access the app but eventually the pop up new info screen shows up and freezes me out.
- App can no longer access my Adobe Capture library
Adobe Employee ,
Sarah.
Got your email. I just responded.
Sue.
Mar 04, 2017 Mar 04, 2017
Hi Sheena,
I have 105.27 gb on my iPad which should be more then efficient for the application?
Danielle Rabinowitz
Adobe Employee ,
Mar 05, 2017 Mar 05, 2017
Hi Danielle,
Can you email me through the in-app feedback so I can try to help? I'm not sure what version of the app you're using, but... tap Settings (in the lower nav) then Send Feedback.
Sue.
Hi Sue,
I can't email you from the app because it keeps crashing when I open it...
Danielle Rabinowitz
Adobe Employee ,
Mar 06, 2017 Mar 06, 2017
Hi Danielle.
I'm going to private message you here.
Sue.
