(I am using a mac) I bought an E-Book from human kinetics for school. I downloaded Adobe Digitals Edits just like the instructions said. If I try to authorize the computer using my Adobe ID I get this error: Incorrect login ID or password for the selected eBook vendor. Please try again. I contacted adobe customer support and got to chat briefly with a person saying that they could not answer my question. So after many hours searching here I have tried a few things but nothing have worked.
1. I know my email and password are correct
2. My password does not contain any signs other than letters and numbers, which you have to have according to Adobe ID (tried to change it to see if that would work)
3. I get the same error both when I start the authorization when the program is opened, and when I try to open the book first.
4. I can not do the cmd + shift + D thing, because I have never authorized the app before and it is not even an option (tried that too)
5. I have tried uninstalling it and installing it again, and using another version of the program. I also tried using the app on my iPhone.
I really need help as the book is really expensive and I am going to use it when I am going to the university.
Note: moderated to remove personal information from the post, R. Neil Haugen
I don't know if you read the questions here before you answer, but as I already have written: I have no umlaut or special characters in my password, only letters and numbers and a capital letter.
You are a umlaut or special character in your Passwort? If yes change it to only numbers and letters.
What you mean with capital letter?
It worked for me.
Curious to learn WHAT worked for you... I tried changing my password so it contains no symbols, only a string of lowercase characters and numbers. But it doesn’t bring me any further, I still can't authorize ADE on my Mac even though the AdobeID & password are 100% correct.
To be honest, it is a quite embarrassing experience a serious company like Adobe is presenting to its law abiding customers (I can't open & read the ebooks I bought on my Mac).
sorry for the misinformation.
This one worked:
I had a similar problem, but I was trying to log in to OverDrive instead of AdobeID.
I'll just paste the instructions the library sent me
"When you go to authorize computer, you should see some blue writing to the side of the Adobe ID box, which says ‘sign up for an Adobe ID’. Following the instructions will let you create a new Adobe ID which you can then use to attempt authorization."
"If this still does not work, try resetting your Adobe ID’s password."
I created a new Adobe ID and was able to log in with that and then open my DRM ebook just fine.
Overdrive users - turns out I didn't need to log in with Overdrive credentials at all (possibly because my Overdrive account has the same email address associated, I'm not sure - I logged in to overdrive.com to associate the email address, it previously just had my library card number and PIN)
Turn off the Two-step verification (TwoFactorAuthentication).
It helped me. 😕
Hi, i was having trouble logging in too and after trying every suggestion I found online, I finally managed to find a solution that worked. As I was trying to authorize the device (my ipad) on ADE, I entered my email without problem but as soon as I tried to enter the password it immediately assumed "secure password" and wouldn't let me change it. As a result it showed "incorrect password". In desperation, I kept clicking on the space reserved for the password and eventually it showed the possibility of scanning the text. So I wrote down my password on my iPhone, scanned it so it appeared on that space, authorized it... and it worked!
