Hi all,
I am trying to setup edge server with RTMPS protocol.
I am follow below link to setup edge and origin server.
https://helpx.adobe.com/adobe-media-server/config-admin/configuring-security-features.html
I can connect directly to the origin server via RTMPS.
But when I want to connect to the origin server through the edge server via RTMPS. I got a error message below.
2017-03-06 15:55:23 27109 (i)2581223 Core (27654) is no longer active.
2017-03-06 15:55:23 27109 (w)2581256 Core (27654) _defaultRoot_:_defaultVHost_:::_0 experienced 1 failure
May I missing some setting?
AMS version: AMS_5_0_6_r6102
Below is my setting.
origin-server/ams.ini
ADAPTOR.HOSTPORT = :1935,-443
origin-server/Server.xml
<SSL>
<SSLRandomSeed>16</SSLRandomSeed>
<SSLSessionCacheGC>5</SSLSessionCacheGC>
<SSLClientCtx>
<SSLVerifyCertificate>true</SSLVerifyCertificate>
<SSLCACertificatePath></SSLCACertificatePath>
<SSLCACertificateFile>/opt/adobe/ssl/gd_bundle-g2-g1.crt</SSLCACertificateFile>
<SSLVerifyDepth>9</SSLVerifyDepth>
<SSLCipherSuite>ALL:!ADH:!LOW:!EXP:!MD5:@STRENGTH</SSLCipherSuite>
</SSLClientCtx>
</SSL>
origin-server/_defaultRoot_/Adaptor.xml
<SSL>
<SSLServerCtx>
<SSLCertificateFile>/opt/adobe/ssl/my_domain.crt</SSLCertificateFile>
<SSLCertificateKeyFile type="PEM">/opt/adobe/ssl/my_private.key</SSLCertificateKeyFile>
<SSLPassPhrase></SSLPassPhrase>
<SSLSessionTimeout>5</SSLSessionTimeout>
<SSLVerifyClient log="false">none</SSLVerifyClient>
</SSLServerCtx>
</SSL>
edge-server/ams.ini
edge-server/Server.xml
<SSL>
<SSLClientCtx>
</SSLClientCtx>
</SSL>
edge-server/_defaultRoot_/Adaptor.xml
<SSL>
<SSLServerCtx>
</SSLServerCtx>
</SSL>
edge-server/_defaultRoot_/_defaultVHost_/Vhost.xml
<Proxy>
<Mode>remote</Mode>
<RequestTimeout>2</RequestTimeout>
<Anonymous>false</Anonymous>
<CacheDir enabled="false" useAppName="true">
<Path></Path>
<MaxSize>32</MaxSize>
</CacheDir>
<LocalAddress></LocalAddress>
<RouteTable protocol="rtmps">
<RouteEntry>*:*;origin.mydomain.com:443</RouteEntry>
</RouteTable>
<EdgeAutoDiscovery>
<Enabled>false</Enabled>
<AllowOverride>true</AllowOverride>
<WaitTime>1000</WaitTime>
</EdgeAutoDiscovery>
<SSL>
</SSL>
<AggregateMessages enabled="true">
</AggregateMessages>
</Proxy>
edge-server/core.00.log
#Fields: date time x-pid x-status x-ctx x-comment
2017-03-13 14:42:41 9384 (i)2581237 Starting admin app on core (9384). -
2017-03-13 14:42:41 9384 (i)2581238 Core (9384) connecting to admin. -
2017-03-13 14:42:41 9384 (i)2581231 Core (9384) connected to admin. -
2017-03-13 14:42:41 9384 (i)2581234 Core (9384) connection to admin accepted. -
2017-03-13 14:42:41 9384 (i)2631174 Listener started ( _defaultRoot_ ) : 127.0.0.1:19351 (rtmfp-core)/v4 -
2017-03-13 14:42:41 9384 (i)2631174 Listener started ( _defaultRoot_ ) : 192.168.10.132:19351 (rtmfp-core)/v4 -
2017-03-13 14:42:41 9384 (i)2631509 Public rtmfp-core addresses for listener _defaultRoot_ are: 127.0.0.1:19351;192.168.10.132:19351 -
2017-03-13 14:42:41 9384 (i)2581246 Core (9384) sending register cmd to edge. -
edge-server/edge.00.log
2017-03-13 14:42:28 8926 (i)2581173 AMS detected IPv6 protocol stack! -
2017-03-13 14:42:28 8926 (i)2581173 AMS config <NetworkingIPv6 enable=false> -
2017-03-13 14:42:28 8926 (i)2581173 AMS running in IPv4 protocol stack mode! -
2017-03-13 14:42:28 8926 (i)2581173 Host: localhost.localdomain IPv4: 192.168.10.132 -
2017-03-13 14:42:28 8926 (i)2631174 Listener started ( _defaultRoot__edge1 ) : localhost:19350/v4 -
2017-03-13 14:42:29 8926 (i)2631174 Listener started ( _defaultRoot__edge1 ) : 443 (secure)/v4 -
2017-03-13 14:42:29 8926 (i)2631174 Listener started ( _defaultRoot__edge1 ) : 1935/v4 -
2017-03-13 14:42:30 8926 (i)2631174 Listener started ( _defaultRoot__edge1 ) : 127.0.0.1:19350 (rtmfp-core)/v4 -
2017-03-13 14:42:30 8926 (i)2631174 Listener started ( _defaultRoot__edge1 ) : 192.168.10.132:19350 (rtmfp-core)/v4 -
2017-03-13 14:42:30 8926 (i)2631509 Public rtmfp-core addresses for listener _defaultRoot__edge1 are: 127.0.0.1:19350;192.168.10.132:19350 -
2017-03-13 14:42:30 8926 (i)2631174 Listener started ( _defaultRoot__edge1 ) : 127.0.0.1:1935 (rtmfp)/v4 -
2017-03-13 14:42:30 8926 (i)2631174 Listener started ( _defaultRoot__edge1 ) : 192.168.10.132:1935 (rtmfp)/v4 -
2017-03-13 14:42:30 8926 (i)2631174 Listener started ( _defaultRoot__edge1 ) : 127.0.0.1:443 (rtmfp)/v4 -
2017-03-13 14:42:30 8926 (i)2631174 Listener started ( _defaultRoot__edge1 ) : 192.168.10.132:443 (rtmfp)/v4 -
2017-03-13 14:42:40 8926 (i)2581252 Registering core (9213). -
2017-03-13 14:42:40 8926 (i)2581250 Edge disconnected from core (9213). -
2017-03-13 14:42:41 8926 (i)2581252 Registering core (9384). -
2017-03-13 14:42:41 8926 (i)2581250 Edge disconnected from core (9384). -
edge-server/master.00.log
#Fields: date time x-pid x-status x-ctx x-comment^M
2017-03-13 14:42:27 8900 (i)2581173 AMS detected IPv6 protocol stack!
2017-03-13 14:42:27 8900 (i)2581173 AMS config <NetworkingIPv6 enable=false>
2017-03-13 14:42:27 8900 (i)2581173 AMS running in IPv4 protocol stack mode!
2017-03-13 14:42:27 8900 (i)2581173 Host: localhost.localdomain IPv4: 192.168.10.132
2017-03-13 14:42:27 8900 (i)2571011 Server starting...
2017-03-13 14:42:28 8900 (i)2581413 /opt/adobe/ams/Apache2.2/bin/httpd -f ./conf/httpd.conf -d "/opt/adobe/ams/Apache2.2" -k start returned 0: [Mon Mar 13 14:42:27 2017] [info] mod_jithttp - AMS installation path: "/opt/adobe/ams/"
httpd: Could not reliably determine the server's fully qualified domain name, using localhost.localdomain for ServerName
2017-03-13 14:42:28 8900 (i)2581413 /opt/adobe/ams/Apache2.2/bin/htcacheclean -n -t -i -p/opt/adobe/ams/Apache2.2/cacheroot -d5 -l1024K returned 0:
2017-03-13 14:42:28 8900 (i)2581224 Edge (8926) started, arguments : -edgeports ":1935,-443" -coreports "localhost:19350" -conf "/opt/adobe/ams/conf/Server.xml" -adaptor "_defaultRoot_" -name "_defaultRoot__edge1" -edgename "edge1".
2017-03-13 14:42:28 8900 (i)2571111 Server started (/opt/adobe/ams/conf/Server.xml).
2017-03-13 14:42:40 8900 (i)2581221 Core (9213) started, arguments : -adaptor "_defaultRoot_" -vhost "_defaultVHost_" -app -inst -tag "_0" -conf "/opt/adobe/ams/conf/Server.xml" -name "_defaultRoot_:_defaultVHost_:::_0".
2017-03-13 14:42:41 8900 (i)2581223 Core (9213) is no longer active.
2017-03-13 14:42:41 8900 (w)2581256 Core (9213) _defaultRoot_:_defaultVHost_:::_0 experienced 1 failure
!2017-03-13 14:42:41 8900 (i)2581221 Core (9384) started, arguments : -adaptor "_defaultRoot_" -vhost "_defaultVHost_" -app -inst -tag "_0" -conf "/opt/adobe/ams/conf/Server.xml" -name "_defaultRoot_:_defaultVHost_:::_0".
2017-03-13 14:42:43 8900 (i)2581223 Core (9213) is no longer active.
2017-03-13 14:42:43 8900 (i)2581223 Core (9384) is no longer active.
2017-03-13 14:42:43 8900 (w)2581256 Core (9384) _defaultRoot_:_defaultVHost_:::_0 experienced 1 failure
