stopped working old scripts with the command
ScriptUI.newImage(imgs[0]);
Error - Invalid image data. In JS Guide write:
ScriptUI.newImage ( normal, disabled, pressed, rollover );
normal - The resource name or path to the image to use for the normal or default state.
I tried to specify the path to the file with the text to make a resource using File(). The error does not change.
Please tell me how to fix it ?
Could you post the full script
so you can not do much
var sui_imgs, imgs = new Array();
var folder = "/c/temp/test";
var files = folder.getFiles();
for (var n = 0; n < files.length; n++) {
sui_imgs.push(ScriptUI.newImage(files
I do nor know ScriptUI or javaScript onle hack at it your script code did not work at all on my machine. I made some changes it come close not but ScriptUI I know nothing about that part.
var sui_imgs = new Array();
var imgs = new Array();
var folder = new Folder("/c/temp/test");
alert('File="' + files
Not worked, Alert is showing and next step gives Error
As I wrote I do not know Javascript or ScripUI. I just hack a little. The code you posted did not work at all. I fixed all but the ScriptUI part which I Know nothing about. It is documented in one of Adobe Scripting manuals it your interested you should read it.
Bonjour
By changing var sui_imgs = new Array ();
By var sui_imgs = new Array ("");
It seems to work ...........
In some old version of Photoshop Adobe changed ScriptUI. Try CC 2015, CC 2015.5 CC 2017 does not work there as the OP wrote.. I still use CC 2014...
I found a bug - temporarily I don't work with his computer, there was the AST CS5t, as soon as put AST CC2015 it worked 🙂 I apologize for the carelessness !
