I need to export a Creative Cloud indd. file into an idml file so it can be used in an older version(CS6) but every time I try to export or save as an idml CC crashes.
I tried a number of times modifying the content in the original indd. and discovered that when I removed pages of the document which included tables on it would export to idml. Is there a problem with downgrading tables created in CC to a file that works in CS6? I could really do with being able to export/save the whole document to idml, has anyone come across this problem?
"has anyone come across this problem?"
Yes, FWIW. CC seems to be touchy when it comes to exporting and importing IDML and can crash. Haven't found an answer yet. It's worth filing a bug report with Adobe.
Your problem is probably more generic. Read points 9, 14, and 17, and 18 (for starters) in my
Adobe InDesign CC 2017 Troubleshooting How-to Guide
One of these suggestions will probably salvage you.
I'll have a look at the tips in the troubleshooting guide and see if anything solves the problem.
Does it work if you package the document?
And in the future, if you need a CS6 document, you might just as well start out in CS6 as long as you’re running an operating system that will support it.
Even when packaging the document crashes at the point of creating the idml.
I do have the option of using CS6 as I still have both at this moment but I was hoping I could focus on using CC since I purchased it recently.
Hi Paul,
the question is what version of CC you would like to trust most.
If there is no particular feature in CC that you have to use CC I'd stay with CS6 8.1.0 if you are more familiar with it.
CC 2017 is new and there is still no bug fix version released.
Because you have a subscription you can install all of the versions of inDesign from CS6 to CC 2017 on your machine and using them side-by-side. So you'd better go with CC 9.3.0, CC 2014.2 or CC 2015.3, maybe alternatively: CC 2015.4.1.
Uwe
But back to your problem with crashing.
Yes, there is a problem with "downgrading tables" from CC 2015 / CC 2017 to CS6 or CC 9.3.0 or even CC 2014.
There is a new table feature named Graphic Cell.
If you are using this feature extensively you'll see that all your graphic cells are converted to text cells and the images with graphic cells are transformed to anchored objects.
Before, table built with CC 2017 using graphic cells:
After opening with CS6 using IDML exchange:
Note the different insets in the cells.
Example: In CC 2017 you cannot see any differences with cell 1 and cell 2. But internally there are differences in inset values.
Before the cells were converted from text cells (default) to graphic cells, cell 1 and cell 2 had different inset values.
These values do show up again after opening the IDML with InDesign CS6 where the import mechanisms tries its best to read out valid infomation. All that's not known to CS6—graphic cell attributes—is ignored.
Uwe
I was having the hanging on IDML export issue with a simple layout. I could
Solve the issue by creating a new empty Indesign File and moving all the pages from the old buggy file into the empty file using the Move Pages command in the Pages Palette.
