I am running Lightroom version: 6.8 [ 1099473 ] on a Intel box using win 7 Pro. With this latest version... I am reviewing photos using the film strip. As I go along making development adjustments... I move certain photos into collections. Moving from one photo to the next on the film strip becomes slower... and dragging a photo to a collection eventually fails... meaning you can not grab a hold of the photo to add it to a collection. and at this time LR crashes. I do not have this problem on my WIN 10 laptop. This only started after the latest version of LR was installed. Another issue is also in this load... when you delete rejected photos.. the photo in the development window becomes stuck... there is not change to the photo in the center window when select other photos. A restart of LR is only solution.
This is the latest problem report..
Description
Faulting Application Path: C:\Program Files\Adobe\Adobe Lightroom\lightroom.exe
Problem signature
Problem Event Name: APPCRASH
Application Name: lightroom.exe
Application Version: 6.8.0.10
Application Timestamp: 58417e06
Fault Module Name: StackHash_00a8
Fault Module Version: 6.1.7601.23572
Fault Module Timestamp: 57fd0651
Exception Code: c0000374
Exception Offset: 00000000000bf3e2
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional Information 1: 00a8
Additional Information 2: 00a86b88c313a6f2be9ba9a7ae0d53cc
Additional Information 3: 89d1
Additional Information 4: 89d129fb53e9a31d2d15adfed509c2f7
Extra information about the problem
Bucket ID: 393914542
Any ideas??
Have you tried to deactivate the GPU acceleration?
Axel
Axel
Hi LR_Mowang ,
Please try unchecking "Use graphics processor" from Preferences>Performance panel in Lightroom as Axel mentioned.
This is a known issue with the current version and will be fixed in future releases.The workaround is to delete files in the Library module.
Hope that helps.
Akash
