Adjustment Layers Stop Working Mid Way Through Comp?
Mar 06, 2017 Mar 06, 2017
Hello,
Thanks for taking a second to see if you can help with this! I have a comp with a couple of adjustment layers (very specifically, I'm giving a piece an old look with the instructions from this YT tutorial: HOW TO CREATE AN OLD FILM LOOK USING AFTER EFFECTS - YouTube ). The "Scratches" adjustment layers work fine for most of the composition (which runs just under 5 minutes now), but suddenly stop working about 3 minutes in. They don't disappear - they just freeze/stop changing. I can see this in both preview mode, and after rendering it out. I've got a solid desktop with 16 MB RAM, and the newest/2017/cloud version of AE.
Any ideas why these two adjustment layers would suddenly stop adjusting halfway through a composition?
Really appreciate your input! Thank you!
B
[Here is the list of all Adobe forums... https://forums.adobe.com/welcome]
[Moved from generic Cloud/Setup forum to specific Program forum... Mod]
887
No idea without seeing the modified properties of the layer that is giving you problems. I suspect that you might be running into a counting limit somewhere.
If the comp one five minute shot? if so you may have to change the settings somewhere. If there is more than one shot in the composition then break the movie into multiple compositions. AE is best suited to creating shots that you can't create in a NLE. It's a lousy editing tool.
Enthusiast ,
Do your keyframes extend all the way to the end of your composition? It sounds like your end keyframes on your adjustment layers are at the 3 minute mark, when they should be at the end of your timeline.
Adobe Employee ,
May 15, 2017 May 15, 2017
Hi BrianB,
Sorry for this issue. Did you ever find a solution? Please let us know if our experts’ advice helped you or if you still need help.
Kevin
Mar 08, 2022 Mar 08, 2022
Hi everyone,
Almost exactly 5 years after the OP, I had this problem. After an entire afternoon fighting and searching where the problem is, I wasn't able to find it. But my work around was to create another composition and start using the adjustment layer at the beginning of the composition, so once stitch together everithing worked out.
Mar 09, 2022 Mar 09, 2022
Impossible to tell what the original issue is, glad you've got it sorted though.  Any chance you could post of a screenshot of the entire application with the comp where it's not working visible?
Oct 26, 2022 Oct 26, 2022
Same thing with me. I copied all of the layer in the old pre-comp, paste it in the main comp, and make a new pre-comp from that layers, and voila it works just fine. It's kinda silly, but hey it works just fine
Oct 27, 2022 Oct 27, 2022
Hi, unfortunately I also had the same problem and it still hasn't been solved. It is very surprising that no attention is paid to her at all.
Jan 13, 2023 Jan 13, 2023
smae here, i have a time*number so.. it should work all the way, yet it does not,
