Hi I have a PNG file which is a sequence from left to right in the 1 file. Is it possible to load this file or render it so I can play the sequence?
Example is a chimney stack on the left and the further to the right you look on the image the chimney has more and more smoke coming out of it and then down to no smoke again. Then the sequence should restart.
Many thanks.
Hi KingDave,
Could you please provide some screenshots so that we can understand the issue and help you out?
Please check the links below and let us know if it works: -
Create frame animations in Photoshop
How to Make an Animated GIF in Photoshop [Tutorial]
Sahil
Hi KingDave,
Sahil
