Has anyone run into issues copying a sequence colored with Lumetri from Premiere 2017 to AE2017?
Last week I kept getting an error in AE when trying to paste a sequence from Premiere. AE would error after one clip (dialogue below) and paste only that one clip. So I had to copy/paste one clip at a time to get the sequence imported.
This didn't happen to the sequence before it was colored with Lumetri. This copy/paste method worked with Lumetri prior to 2017.
Error:
After Effects: AEGP Plugin Premiere Pro Import: Error reading effect info. Some effects will be skipped. ( 5027 :: 12 )
Mac Pro (2013)
OS X 10.10.5
AE 14.0.1.5
PPro 11.0.2 (47)
You're not running the latest versions. I'm not sure if the issue you are asking about is fixed, but it's the first thing I would try (as long as you're not in the middle of a big project, of course).
Looks like we were .1 versions behind in AE (14.0.1.5 vs 14.1). This seems to have fixed this in a super quick test. Luckily IT didn't have a problem pushing the update. They're normally pretty cautious about updates, which is probably why I didn't have it to begin with haha
Disappointed none of the devs pointed this out in the Slack when I asked and provided version numbers
Thanks for the suggestion!
In their defense, they have a TON of forums, reddits, and Slacks they semi-monitor in addition to their own Adobe-based Slacks and emails. When trying to read quickly through an issue, 14.0.1 can look an awful lot like 14.1.0.
Anyway, I'm glad my suggestion helped!
They are pretty great. I was just being a curmudgeon
